Results 1 to 15 of 54
Thread: which milling arbor
16th Mar 2011, 12:50 AM #1Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
which milling arbor
can some one please tell me which spindle arbor a kondia turret mill would have. its a mill the style of a bridge port. is it a R8? is this called another name.
16th Mar 2011, 07:08 AM #2Pink 10EE owner
- 6,216
Without a picture of the spindle no one can tell you what it will be..
Could be R8 could be ISO30 or ISO40.
16th Mar 2011, 09:27 AM #3Dave J Guest
Here is a chart with measurements to find out what yours is.
Machine Tool Shanks (Tapers)
Dave
16th Mar 2011, 10:19 AM #4Most Valued Member
- Oct 2010
- 1,910
ok that makes sense. ill get a photo. and measure it up from the chart.
thanks
16th Mar 2011, 10:22 AM #5Most Valued Member
- Oct 2010
- 1,910
it look like a iso 30. not shore until i measure it thou
16th Mar 2011, 11:47 AM #6Dave J Guest
If it's a ISO 30 it will have 2 drive blocks either side of the spindle taper hole, or if they are missing it will have 2 milled flats either side with M6 taped holes for them.
Dave
16th Mar 2011, 03:25 PM #7Pink 10EE owner
- 6,216
There is an outside chance it could be an ISO40..
16th Mar 2011, 06:13 PM #8Dave J Guest
The ISO 40 taper should be easy to pick up over the smaller tapers because it has a larger gauge line measurement of 1.750 inch or 44.45mm, where as the R8 and the ISO30 could be confused because they both look to have a gauge line measurement of 1.250 inch or 31.75mm.
If you measure the inside of the end of the spindle and then look up in there at the ground taper, the ISO 30 has a long taper compared to the short R8.
Either way there is plenty of tooling around for both, but you will find the R8 to be cheaper.
Dave
16th Mar 2011, 07:14 PM #9Pink 10EE owner
- 6,216
The drawbar thread would be a give away as well..
AFAIK R8 uses a 7/16 thread..
ISO30 uses 1/2W or 1/2 UNC or 12mm coarse or 12mm fine..
16th Mar 2011, 08:36 PM #10Golden Member
- Apr 2009
- Kingswood
- 930
My Kondia FV1 is fitted with an NT/ISO 30 taper in the spindle.
The ER chucks are M12 drawbar, and I have some BEL DA 180 chucks with imperial drawbar, not sure if 1/2 in or 3/8 in.
John.
16th Mar 2011, 09:26 PM #11Most Valued Member
- Oct 2010
- 1,910
thanks john. ill measure the arbor up tonight. i think thats the one in the machine im talking about. does this mean a r8 wont fit if it takes an iso30? its a machine at work. theres a about zero chance of them buying any tooling, i think they would prefer to get rid of the machine.
16th Mar 2011, 09:34 PM #12Most Valued Member
- 4,887
To save having to measure to much when you get to work stick your finger up the centre of the spindle, run it around the ID,if you feel a little lump it will be an R8,if theres no lump measure the ID of the opening at the bottom of the spindle,if its 1 1/4" its a 30,if its 1 3/4" its a 40.
16th Mar 2011, 09:47 PM #13Most Valued Member
- Oct 2010
- 1,910
um this isnt looking so good
thanks pipe clay. that's a great no mucking around method . i just have a bad feeling the cutter i just bought wont fit.
Attachment 164383
16th Mar 2011, 10:14 PM #14Most Valued Member
- 4,887
With that being an R8 hopefully you will feel the lump inside the bore.
16th Mar 2011, 10:36 PM #15I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,270
Cutter Arbor
By Woodlee in forum METALWORK GENERALReplies: 0Last Post: 24th May 2009, 07:33 PM -
Which 2MT-JT6 Arbor do I need?
By John H in forum METALWORK GENERALReplies: 13Last Post: 7th Nov 2008, 03:48 PM
