Results 1 to 11 of 11
Thread: To cut thin steel?
20th Feb 2011, 09:34 PM #1Novice
- Aug 2009
- Melbourne Vic
- 10
To cut thin steel?
Hi all
I have not needed to work with steel until now
I want to cut a galvanised steel sheet into strips about 20 mm wide and .5 mm thick but because of the quantity required using snippers may not be a good idea not an angle grinder either. What be the next best thing around a hand guillotine perhaps?
Thank you f
20th Feb 2011, 09:36 PM #2
20th Feb 2011, 10:22 PM #3Dave J Guest
21st Feb 2011, 01:32 AM #4.
- 6,459
I'm Impressed
You're a clever fellow Dave. Where'd you learn all this?
Bob.
21st Feb 2011, 02:31 AM #5Dave J Guest
It's just things I pick up over the years.
Dave
21st Feb 2011, 06:03 AM #6Most Valued Member
- 4,890
Or they might even use their back gauage.
21st Feb 2011, 06:32 AM #7
Yeah the sheet shop certainly is the way to go. We used to get a whole sheet cut into strips at a time. Now since finding a local supplier that already has them in near enough width to suit our needs we simply buy em in. No sharpish edges to clean either. Can it be 19 mm wide? Does it have to be gal? Would ally be fine? Cause the ally strip we buy in is about 1 mm thick. By the time one cuts it manually or outsuources it to a shop.....
Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
21st Feb 2011, 07:11 AM #8Most Valued Member
- 4,258
yep ...an apprentice I know was sticking his tape measure thru to check his sizes...ah thats good and then put his foot on the pedal...chomp...cut the sheet right where he wanted it...and his tape...hahaha
I found this out after he borrowed my tape and did the same thing....hahahaha...i didnt laugh back then tho
21st Feb 2011, 07:12 AM #9Most Valued Member
- 4,258
cant use hoop iron from the hardware store?..it is about those sizes...some where near it anyway
21st Feb 2011, 08:50 AM #10Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
21st Feb 2011, 11:22 AM #11Dave J Guest
I have found the places with the cheaper prices have primitive equipment on the side for smaller jobs so it doesn't tie up their regular work. It is usually the boss or the forman that does it for me, or if they have to set up a machine and pull one of the guys off something else, up goes the price.
Dave
Turning a circle from thin plate steel
By BobL in forum METALWORK GENERALReplies: 2Last Post: 1st May 2008, 09:49 AM
