Results 1 to 12 of 12
Thread: I gave up at this point
5th Jan 2011, 07:45 PM #1Most Valued Member
- 4,258
What do you reckon?
An out of the the box hasn't been adjusted machinists level for US$29 plus delivery
I gave up trying to get the mill level when it got to this...I reckon the cheap chinese level is faulty...what do you think?...
the first 2 are X across the top of the vise, while the other 2 are Y across the tableLast edited by eskimo; 5th Jan 2011 at 07:46 PM. Reason: added content
5th Jan 2011, 08:09 PM #2Golden Member
- Apr 2009
- Ballina N.S.W.
- 644
Eskimo,
Just make sure you don't drop it as it will drive you nuts getting it to read that good ever again.
Bob
5th Jan 2011, 08:11 PM #3Senior Member
- Riverina NSW
- 169
Looks good enough to me as long as the buble aint just a picture taped on.lol
5th Jan 2011, 08:21 PM #4Dave J Guest
Have you adjusted it?
Dave
5th Jan 2011, 08:26 PM #5Most Valued Member
Well as long as delivery wasnt $150
Think mine cost $170
Is it 0.02/1000mm?
5th Jan 2011, 08:59 PM #6Dave J Guest
I thought you bought one from CDCO and one from CTC, I haven't seen any $29 levels at either, are you going to let us in on the secret?
Dave
Edit
I haven't tried my CTC one yet, looks OK thoughLast edited by Dave J; 5th Jan 2011 at 09:01 PM. Reason: Edit
5th Jan 2011, 10:25 PM #7
Looks pretty good to me .
If the level reads the same when you end for end it then you don't have a problem .
The graduations on the vial usually denote .002" per foot if it's an imperial level .
Kev."Outside of a dog a book is man's best friend ,inside a dog it's too dark to read"
Groucho Marx
6th Jan 2011, 08:22 AM #8Most Valued Member
- 4,258
Old fella...no its not taped
Dave...that is the six inch one from CTC....yeah the web site says AU$49 but the invoice actually shows AU$24.50...(not 29)...creative accounting by Heine?
And no I have not adjusted it...
The one 8inch one from CDCO is out loan....
& guys its the .02mm/M
6th Jan 2011, 08:35 AM #9Most Valued Member
- 4,890
What did you use to Level the Mill prior to useing this,is the Mill bolted to the ground,what method of Jacking the Mill did you use and what Material did you use for Shimming?
6th Jan 2011, 09:11 AM #10Most Valued Member
- 4,258
I used a standard hardware store spirit level
x axis wasnt too bad but Y was way way out
No the mill is not bolted...
I have the mill sitting on 4mm steel milled plates
then had various sizes of .6 to 1.6 steel sheet shims to take up any remainder ...then finished off with steel shims if I had correct size, else used brass...
dont tell me I stuffed up ...yet again
6th Jan 2011, 10:37 AM #11Most Valued Member
- 4,890
It is surprising if you allready had the Mill that level with a standard type Spirit level.
I have leveled quite a few very large machines,but never to the accuracy that you have been able to achieve with the Standard type level,well done.
Would suggest to maintain the .0005"/1' that you have,to bolt it then Grout,would try for 1"/25mm of grout.
6th Jan 2011, 11:14 AM #12Most Valued Member
- 4,258
when my concrete layer did east to west leveling he hadnt been drinking...but i guess he'd had few when he did north to south
Pipeclay the level I used to get it to this was the machinist's level..not your standard type...that was what I used when I first put it in....
When I first put the machinists level on it wasnt that far out on X axis...was way out on the Y that I couldnt pick up on the standard type...
but I now have it level...well close enough...
It is amazing...
(I am on heavy black clay......the clay when it dries out shrinks...and for those dont dont know.....everything settles down...and the when it gets wet expands with forces you cant believe moves and can wreck a house.... if not kept at a stable moisture level
when I had the garage built I had a 6 inch slab poured on 6inch compacted rubble base....)
its now getting dry due to summer and although I have garden and keep it watered, you can see the bubble move if I take a step sideways to the mill......its only a small movement but you can see it move....wonder where it will be by the end of summer and then next winter?????
