Page 18 of 21 FirstFirst ... 8131415161718192021 LastLast
Results 256 to 270 of 301
  1. #256
    Aug 2011
    4,779
    Quote Originally Posted by Steamwhisperer View Post
    And it's in Ballarat. Super bargain for me Simon
    Phil
    I was wondering if it was you selling it to buy a milling machine!
  2. #257
    Apr 2013
    Toowoomba Qld
    401
    Was looking at the Max-Pro website, I know they may have just grabbed some stock photos to use on their website but one of the pictures on their website is on my wish list but I'll be honest that I don't know exactly what the industry calls them or where to buy them at a good price
    Any idea's ?
    Also chasing a source on Cob mills / porcupine cutters / whatever they are called.
  3. #258
    6,438
    Thumbs up Gang Cutters.
    Hi Simon,
    I believe that they are called "Gang Cutters" or rather "Side and Face cutters" ganged onto a single arbour. That picture looks like its cutting slots in a table prior to having the "T" milled. I've seen something similar at a machinery exhibition in Manchester UK, a couple or so years ago.
  4. #259
    Jun 2007
    sydney ( st marys )
    64
    4,887
    As stated above Side and Face cutters ganged together.
    Were you particularly after indexable , cemented carbide or HSS.
  5. #260
    6,438
    You may recall that I lamented about 8 imperial tons of similar cutters being sent to scrap. From previous visits I remember seeing rack upon rack of those sort of cutter, both HSS and insert ones. I mentioned a skip full of chucks, jaws and arbours ! Sadly that has now gone. The area is now occupied by wooden crates of, I assume machinery. A couple of container loads I would think.
  6. #261
    Nov 2010
    Gippsland Victoria
    733
    Default Anybody bought from Mag-Pro recently ?
    Hey,
    Anybody purchased anything from Mag-Pro recently, some of the prices look great but am unable to login or even join up as a new account.
    I tried sending them an email a while back and no answer. Am I using the right website ?
    M&G Productions
    Bill
  7. #262
    Aug 2006
    1,105
    He is also on eBay https://www.ebay.com.au/str/mgmachietoolsaccessories
    Might be issues with the website or he could be on holidays still. Try sending a message through eBay.
  8. #263
    Jul 2016
    35
    1,522
    I bought some stuff off him this week but I just email him directly the website just doesn't do it for me.
  9. #264
    Apr 2015
    Tungkillo, South Australia
    87
    74
    I've also bought stuff from their website and haven't been disappointed so far. An ER32 'Jo' Block came close though. The block was really well made and the finish was great, almost polished, but the 12 chamfered edges behind the ER32 nut were just crudely filed. I bought a 160mm dia. round magnetic chuck which looked great. Mounted it on a spare D1-3 back plate and get about .01mm t.i.r. Now waiting for 'precision 100mm vice'.
  10. #265
    Feb 2009
    jilliby nsw
    111
    Quote Originally Posted by Toggy View Post
    It all depends on the quality of HSS you require. If you don't mind cheap, softish HSS that does not hold an edge for long and anneals with too much heat; go the Chinese/Indian made route. If you want a quality product then look at Swedish, Aussie or US made. 10-15% cobalt in the mix makes a very tough and heat resistant steel that will hold an edge for ages. A bit hard when grinding; but holds an edge.
    Ken
    Im in need of some reasonable quality HSS tool blanks 10mm, 12mm & 16mm squares, can you suggest some suppliers that could I could contact please. Needed for lathe & shaper to machine flame cut, built up weld and rougher work that destroys inserts. Thanks for your anticipated input. Cheers
  11. #266
    Oct 2019
    Perth Western Australia
    9
    Default Bump October 2019
    I'm looking for a decent lathe / milling tool supplier of mid to upper range quality. I'm based in Perth Western Australia. At the moment I'm chasing MT3 Collet chuck set, centre drills and end / slot drills. I can get everything local from H&F, but would like to save a few $$$ for more goodies. Any positive recommendations would be much appreciated. Cheers.
  12. #267
    Nov 2019
    Brisbane
    69
    452
    Default Imports.
    Quote Originally Posted by hpa1 View Post
    Hello from Bernie.
    I bought some imperial M42 tool bits from Victor machinery in USA. The price was soooo low I put up a ? When they arrived the packet stated made in China. . So I ground the first bit and used it in my shaper on rough steel plate. The working life is amazing, tool edge holds well. It is the hardest to grind tool steel I have seen in 50 yrs of use. Delivery is OK in $.
  13. #268
    Apr 2019
    Adelaide
    589
    Has anybody bought one of the 6 or 8" milling vices from M&G Productions? Very cheap but not worth much if the tolerances are not tight.
    I see they sell the Create multi-fix tool posts. Do they not make everything they sell?
    Are you buyers generally happy with their stuff? I ask as I need to order a heap of cutters and collects.
  14. #269
    Nov 2017
    Geelong, Australia
    57
    2,651
    Find Karl Robbers recent thread about looking for a vice. Quite a bit of info in there.
  15. #270
    Jul 2016
    35
    1,522
    I think the only thing he actually makes is drills. IMO the drills aren't that great but I've been happy with most of the other stuff. His prices on create were good, better than factory and less shipping.
  1. CTC Tooling
    By krisfarm in forum METALWORK GENERAL
    Last Post: 27th Mar 2010, 10:53 PM
  2. Lathe Tooling
    By glock40sw in forum METALWORK GENERAL
    Last Post: 13th Aug 2007, 08:39 AM
