Results 1 to 6 of 6
Thread: AL960 funny noise
12th Dec 2010, 12:45 PM #1Member
- May 2010
- tasmania
- 96
AL960 funny noise
I have been doing some low-speed screwcutting and notice that there is a vibration as the lathe slows down after switching it off. I did not particularly notice it before when doing higher speed work but it does it as the lathe slows from any speed when I checked it today.
It seems totally normal when actually running with no significant vibration even at the slowest setting.
I wonder if it is the spindle bearing
Am I worrying about nothing?
P.S the AXA toolpost is going very nicely
12th Dec 2010, 12:53 PM #2Pink 10EE owner
- 6,216
Often you find high speed shafts/gears will resonate and vibrate at a certain speed, and they will not vibrate at any other speed...
12th Dec 2010, 01:18 PM #3Dave J Guest
If it seems fine when running, I don't think it will be the bearings.
I would change the belt first, most of these machines are supplied with cheap belt's.
Dave
12th Dec 2010, 06:22 PM #4Member
- May 2010
- tasmania
- 96
figured it out
The advice about the belt jogged me into action. I had just replaced the belt as the stock one is a bit short to easily get into the slow pulley (in fact the size specified on the belt is right- It is actually a size smaller than marked!).
To get the belt onto the slow pulley it is necessary to remove the 120/127 gear (I hope that the designer has been sent to the salt mines).
Anyway, I have just had a bit of a play round and found that the noise is coming from the gear train. I had not properly adjusted the mesh when I put the 120/127 back on
Properly adjusted, all is sweet.
12th Dec 2010, 08:08 PM #5Dave J Guest
Good to hear you got it sorted.
Dave
12th Dec 2010, 09:11 PM #6
I agree, the belt change is one of the few niggles with the 960B, I tend to leave mine in low position as the slowest speed in high range is too fast for screw cutting and I do a lot of that and parting off. The size marking on the belt is confusing. According to the local bearing & belt bloke, the Taiwanese & Chines measure the belt length at the bottom of the pulley groove whereas the poms and yanks measure it halfway up the side of the pulley sheaves - hence the different markings.
When I set the mesh for the 120/127 gear I use a piece of thin paper between the gears to set the gap. It' an old trick but it works for me, I generally use a bit of newspaper.
al960 b woes
By rfurzer in forum METALWORK GENERALReplies: 9Last Post: 27th Oct 2010, 10:21 PM
