Results 1 to 15 of 17
Thread: Fitting an ER 40 to an AL320G
6th Nov 2010, 03:29 PM #1
Further to Eskimo's thread......
I wanted to fit an ER collet to my AL320 but keep the throughbore for longer lengths but all the suggestions made were to use a drawbar on it. Special thanks to Kev In Katherine for thinking outside the square and helping someone with limited experience to knock it up.....
Step 1, bought an ER40 collet holder and some 200sq x 20mm rolled plate - I had some 75mm round and then proceeded to cut the shaft off the holder and turn the plate round and fit it to the registration boss on the lathe back plate. It needs to be taken slow to get the correct fit but as the mountin screws are drilled through, it should align in the correct position. To ensure it goes on the same way each time, I stamped and numbered the holes. I then cut a fillet to weld the round onto the face of the backplate.
Attachment 152180Attachment 152181Attachment 152182Attachment 152183
Attachment 152184Attachment 152185
Attachment 152186Attachment 152187
Attachment 152188
6th Nov 2010, 03:39 PM #2
Step 2 involved welding the housing (which a mate did for me) onto the adapter plate and then turning that round, boring it out to accomodate the holder and then drilling and tapping for two grub screws to lock it in. Those grub screws lock onto the milled flats on the collet holder to hold it in place.
Attachment 152191Attachment 152192
Attachment 152193Attachment 152194
Attachment 152195Attachment 152196
Attachment 152197Attachment 152198
Attachment 152199
6th Nov 2010, 03:43 PM #3Dave J Guest
Good work I need to make one myself one day. I don't do much collet work, but would be handy for some things.
Commercial ones are available if someone wants to go that way.
Chronos Ltd Lathe Type Collet Holders for ER Collets
Lathe collet chucks for metalworking lathes buy on line from Warco
Tools4cheap LLC Online Machine Shop Tooling Store: Mill Tooling,ER Collets and Chucks
Dave
6th Nov 2010, 03:59 PM #4
The final step was to fit it up, face it off and then turn down to a more respectable shape - once it was all done, I measured the TIR at 8 thou.....I put that down to firstly my feeble attempts at machining my first project, secondly the grub screws are not a precise lock and lastly, there would undoubtedly be some play in the fit between the holder and the housing as it is not securely fitted aside from the grub screws........even to the best of my abilities someone more competent could reduce it even further
Attachment 152200Attachment 152201
Attachment 152202
This was a first attempt, it works and I have managed to work on long rods through the spindle bore as I intended without a drawbar.
The next Mk II model, I will attempt to reduce the TIR by boring a taper for the collets into some round fitted similarly mounted on an adapter plate........and then copying the thread for the locking nut....thereby not using a bought collet holder
All up cost of materials? not including the collet holder and set of collets, about $40 but priceless in terms of experience (thanks Kev....and see, not a drop of blood in any picture... .)
So Eskimo.........., it can be done (a lot better than me) but this is just one way I chose....hope it helps.....Lee
6th Nov 2010, 04:08 PM #5
Dave, I looked at the commercial ones and spoke at length with Jeff Beck at Tool4Cheap but none were available in ER40 and those that were for other series, did not come with a correct registration to fit the AL320.....LMS was close, in terms of overall size but the freight would sting....then it would have to be adapted in any regard ......I thought if I had to cut a bought one, then holding it would be a bugga too in the 3 jaw so I might as well start from scratch and learn how to make it myself - at least if I stuffed it up then no great financial loss........
6th Nov 2010, 06:26 PM #6Dave J Guest
Hi,
Don't get me wrong, I think you have done a good job and only posted the links for the lazy ones. LOL
One suggesting for getting less run out would be to set up a dremel or similar tool as a tool post grinder and take a light slim off the ER taper. Doing this will get you down in the low 10th's for run out.
Another way is you could machine a 20-25mm bar true in your 3 jaw to suit the largest collet you have, then put collet in your chuck and mount it on this bar backwards and face off the back of the plate to run true. That way when you turn it around and mount it, it will be running dead true with the collet taper so it will only need to be centered.
I have not had a look or used one of the commercial ones, but I doubt they would be dead true strait out of the box.
What type of registration does the AL320 have?
Dave
6th Nov 2010, 06:54 PM #7Pink 10EE owner
- 6,216
6th Nov 2010, 07:05 PM #8
The AL320G has a fixed flange with three through holes that thread into the chuck or faceplate from the rear of the flange. It has a register that locates the chuck axially machined into the flange. The flange is integral with the spindle.
6th Nov 2010, 07:20 PM #9Dave J Guest
Thanks Gavin.
Dave
7th Nov 2010, 11:31 AM #10Most Valued Member
- 4,255
its a tad out of my league....
i will need to take night classes before I tackle something like that..
maybe one day I might have a go, but for now I might just get a collet chuck
7th Nov 2010, 03:47 PM #11
Eskimo, we've all got to learn otherwise why bother at all??? .....this was my first project and like you, ummed and arred for months thinking along the same lines as maybe I'd overstretched my abilities etc..............but then $40 worth of metal, one or two medicinal frothies and a few hours lathe time is therapeutic enough for me......I'll have a go at MkII with sub micron TIR when the fridge recovers....
This Forum and the people on it are a greatly under utilised resource in your learning process.......it's a huge knowledge base ready to help as I found along the way, so suck it in bloke, and go for it.............don't forget ....lots of pics along the way so we can learn as well.........
7th Nov 2010, 04:43 PM #12Dave J Guest
You have the right attitude and you are right in what your saying, there isn't a day that goes by that I don't learn a new technique or something else new on these type of forums.
If someones not confident, do a trial cut of a taper or a thread on a piece of scrap and when your happy with it do it on the job.
Have you thought about the idea above of mounting it backwards onto a machine true bar and facing the back of it? you may not have to ma MK2.
Here is a picture of the set up I was thinking of to do the facing, you should have minimum run out after doing this.
Dave
7th Nov 2010, 05:01 PM #13
Thankyou Dave.............you're spot on of course - that's one way of truing it up .....especially like the drawings...very clever.......something else I'll need to learn.......
10th Nov 2010, 07:40 AM #14Most Valued Member
- 4,255
Dave
Using your sketch on how to true it up ....
how would you get the bolt holes true?....wouldnt it be that if they are not true then the whole thing will be out of true even after doing what you propose?..remember I am still an apprentice in all of this stuff...hence my question..lol
10th Nov 2010, 01:39 PM #15Dave J Guest
Hi Eskimo,
He said above that it isn't the bolt holes creating the 8 thou it's the grub screws so it's not much.
If after doing this you find the bolt holes are out slightly and you cant get it centered, you could open the holes up larger to let a bit of movement to get it to run true.
The facing could also be done after the two collet chuck parts are pressed/welded/screwed together, before mounting it onto a face plate and drilling holes. You would not get an interrupted cut this way from the drilled holes.
Dave
Spider for AL320G
By Bidgee in forum METALWORK GENERALReplies: 12Last Post: 14th Mar 2010, 11:00 PM -
Al320g
By barkersegg in forum METALWORK GENERALReplies: 6Last Post: 6th Mar 2010, 01:44 PM -
AL320G Gearbox oil
By Gavin Newman in forum METALWORK GENERALReplies: 1Last Post: 25th Apr 2009, 11:23 PM -
AL320G question
By warren in forum METALWORK GENERALReplies: 2Last Post: 4th Apr 2009, 03:37 PM -
Qctp - al320g
By barkersegg in forum METALWORK GENERALReplies: 13Last Post: 27th Aug 2008, 03:19 PM
