Results 1 to 4 of 4
Thread: aluminium
    Aug 2007
    SA
    18
    Default aluminium
    I need to make some heatsinks consisting of 60-65mm ID tubing and a 6-10mm circular insert. At the moment I am looking for price ranges of what I should expect to pay and Adelaide suppliers OR interstate if they are reasonably priced.
    I'm going to probably make 30ish so I am not after huge lot.
    Planning to cut the circles with a hole saw on a drill press and possibly sanding.
    An aluminium leg will be threaded into the plate.
    The external finish is likely to be powder coating if it's cheap enough. If not paint.
    thanks
    Mar 2010
    Nth Qld
    687
    Here's a good article about heatsink design before yoo start powdercoating: ESP - Heatsink design and transistor mounting
    Aug 2007
    SA
    18
    For my use it's not a problem. I may do another finish depending on price but the size is dictated by the fitting I need, not thermal load. With Air flow I can get away with one or two Square cm as a minimum.
    Jun 2009
    Cootamundra
    73
    I buy from these blokes a bit and have found them good.Performance Metals Australia- Home Page
    Scott
  1. Aluminium
    By catbuilder in forum WELDING
    Last Post: 4th Jan 2009, 07:48 PM
  2. Bending Aluminium Bar
    By Dean in forum METALWORK GENERAL
    Last Post: 18th Jan 2008, 03:53 PM
  3. Cast aluminium
    By masoth in forum METALWORK GENERAL
    Last Post: 28th Mar 2007, 01:10 PM
  4. How do I tell if it's aluminium?
    By silentC in forum METALWORK GENERAL
    Last Post: 14th Feb 2007, 08:56 AM
