Results 1 to 15 of 15
Thread: O-Ring Supplier
11th Oct 2010, 08:56 PM #1New Member
- May 2006
- NSW
- 6
O-Ring Supplier
I'm not sure this is the correct forum for my query, but there are so many well-informed and helpful people here I'll give it a go.
I need to replace an O-ring. Its from a garden spray and I don't know the material but I imagine its nothing too special. The size I need has OD about 58 mm. Can anyone suggest where in Sydney I might be able to buy a single (or perhaps 2) ring?. On-line searches produced several suppliers but they deal in 100s.
Norman
11th Oct 2010, 09:01 PM #2
My local (small) hardware store has them by the each.
Kev
11th Oct 2010, 09:03 PM #3New Member
- May 2006
- NSW
- 6
Kev,
Can you be a bit more specific ? I tried my local Bunnies but they didn't want to know.
Normanj
11th Oct 2010, 09:03 PM #4Pink 10EE owner
- 6,218
Any hydraulic shop and some bearing shops....
11th Oct 2010, 09:08 PM #5
11th Oct 2010, 09:48 PM #6New Member
- May 2006
- NSW
- 6
Thanks to KevM and .RC. Given me some helpful ideas to follow up.
regards
SM
11th Oct 2010, 09:58 PM #7Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
+1 for bearing shops. Mine sells things like O-rings and split pins and anything else singly. Dunno how - or why - they do it really. But I'm glad they do.
12th Oct 2010, 01:40 AM #8Golden Member
- Vic
- 48
- 544
The best place for me is renseal in victoria, They have almost everything I need.
12th Oct 2010, 02:12 PM #9
+1 for bearing shops -
CBC locally (Melbourne) has been quite helpful when I needed one of this and one of that to stop oil coming out of an old Ford Dexta rear axle Hydraulic system. Not all was in stock but they got things.
I've also used BSC and found the local store had a bigger range in stock but also had a bigger minimum cash sale.
Both amazingly helpful.
One thing - the easy to get "O" rings are the imperial sizescheers
David
A society grows great when old men plant trees whose shade they’ll never sit in. (Greek proverb)
28th Nov 2010, 01:01 PM #10New Member
- May 2006
- NSW
- 6
Mission Accomplished
Based on advice from this forum I sourced an O-ring from Hooper bearings in Mascot. The staff spent some time to find the best match they could to the damaged ring then let me have it for free. It works well. I'll definitely use them again.
28th Nov 2010, 02:34 PM #11Dave J Guest
29th Nov 2010, 10:12 AM #12Most Valued Member
- 4,258
try
Ludowici
there are a couple of others but I cant recall at the moment...old age
29th Nov 2010, 09:37 PM #13Senior Member
- Sep 2007
- Newcastle NSW
- 77
- 155
Hello Norman,
I just measured the OD of the square section "O"ring which is used on the 50mm (2") S traps used under sinks and wash basins and they are very close to 58mm. The section is about 3mmx3mm . You will get these from plumbers supplies or most hardware stores. Russell
30th Nov 2010, 09:22 AM #14
Most bearing supply shops have them
Two things are infinite: the universe and human stupidity; and I´m not so sure about the universe.
30th Nov 2010, 09:36 AM #15New Member
- May 2006
- NSW
- 6
I've sourced the O-ring
Thanks for the recent posts with suggested sources. As I indicated a few days ago I was able to obtain an O-ring from Hoopers in Mascot so I'm set.
regards
normanj
