Results 1 to 9 of 9
    Jul 2006
    Athelstone, SA 5076
    4,258
    Default Face Mill V End Mill
    I have noted that Shell End Mills and Face mills look the same ...well at least they do to me...
    What is the difference ...can any one explain?
    Adelaide
    68
    1,374
    A face mill cuts on the end of the cutters
    Attachment 146041
    A shell mill cuts on the sides of the cutters.
    Attachment 146042
    An end mill does both but for a smaller area.
    Attachment 146040
    Jul 2010
    Riverina NSW
    169
    Usually an endmill has 4 flutes and they are used to cut keyways which are not blind and a shell mill has a lot more cutting edges and is designed to cut a fair amount off and will cut alot better when only cutting with one side than an endmill.
    Jul 2010
    Riverina NSW
    169
    A Shell end mill is basically a facing cutting when used on a horizontal machine
    near Rockhampton
    6,217
    I thought face mills used inserts, either carbide or HSS (in the old days)
    Shell end mills are smaller and are all HSS and not used today...
    Jul 2010
    Riverina NSW
    169
    You can get shell end mills that use carbide inserts, the main difference is u use a face mill to take cuts off the face of the job and you would use a shell end mill if the majority of the cutting is on the side of the job as you ca remove more material as the cutting edge is longer.
    http://img.directindustry.com/images...mill-35040.jpg
    Aug 2009
    Lake Macquarie
    86
    90
    Eskimo
    Try this as a reference:
    Milling cutter - Wikipedia, the free encyclopedia
    Jul 2006
    Athelstone, SA 5076
    4,258
    mmm
    if you ask me the shell end mill doesnt look any different than the face mill
    example
    Shaw Machinery Web Site
    Jul 2010
    Riverina NSW
    169
    On that page they look the same I would call the shell end mills they have there face mills
  1. 50mm Face Mill and 10 Mitsubishi Inserts for $CHEAP
    By markjaffa in forum METALWORK GENERAL
    Last Post: 11th Sep 2010, 02:23 PM
  2. No. 0 Mill Serial Number and Mill at Work Photos
    By Anorak Bob in forum THE HERCUS AREA
    Last Post: 30th Dec 2008, 03:31 AM
  3. x2 mill
    By beetle in forum METALWORK GENERAL
    Last Post: 4th Jun 2008, 12:41 AM
