Page 91 of 202 FirstFirst ... 41818687888990919293949596101141191 ... LastLast
Results 1,351 to 1,365 of 3016
  1. #1351
    Jul 2014
    eindhoven the netherlands
    69
    That has also reminded me (while maybe not relevant to this) of the dangers of ruptering hydraulic hoseses. We have some hydraulic gear at work and while safety glasses and gloves are generally worn anyway, it's for different reasons with hydraulic gear. A rupture of a hose or part can send a small stream of hydraulic oil strong enough to cut skin. There have been many documented cases of people recieving terrible injuries from this and also the hydraulic oil in the body can cause gangrene requireing aputation of the body part.
    There are some grizzly images on the net of said injuries.
    I concur Michael, a 64mm hose can be a handful with one, two or even three people!
    this is actually where they got the idea for those needleless vaccination guns that are used for mass vaccinations
  2. #1352
    Jan 2011
    Far West Wimmera
    63
    4,049
    Hydraulics usually operate at higher pressures, but even so I was told that water under pressure can also result in amputation.
  3. #1353
    Aug 2011
    4,779
    Quote Originally Posted by janvanruth View Post
    15 lpm at 4000 psi is some serious pressurewasher.
    watch your feet..
    stay safe and have fun
    cheers
    jan
    That's full bore. I don't usually run it at that pressure. I usually have the dump valve set to about 3000 psi. With 4000 psi and a needle 0 deg nozzle, it will remove paint and groove fence posts. Not very helpful for most applications but when used properly with a 30 deg nozzle or the rotating patio nozzle, it's a ripper for cleaning driveways or even pavers.
  4. #1354
    Aug 2011
    4,779
    Quote Originally Posted by Oldneweng View Post
    So true. It is required that you brace yourself before turning on a fire fighting hose valve.
    More so than the CFA truck hose.
    Come to a station with a Scania 4000 LPM pump and I'll show you the meaning of brace!
  5. #1355
    Aug 2010
    Glenbrook NSW Australia
    125
    Lets get serious now....What about the peg.......
    vapourforge.com
  6. #1356
    Apr 2009
    Horsham
    92
    Quote Originally Posted by rusel View Post
    Not too sure. I delivered it and he said that it will do nicely. That was it
    I have learned that its sometimes best not to ask what he wants things for...
    Sorry the answer is not more exciting.
    Jayson.
  7. #1357
    Aug 2011
    4,779
    Quote Originally Posted by Jayson View Post
    Jayson.
    I'm not buying what you're selling! For that amount of work, I need to know more. I suggest you ring him up right now and get more info. Just tell him Simon wants to know!
  8. #1358
    Jul 2006
    Athelstone, SA 5076
    4,255
    and eskimo
  9. #1359
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,540
    Shouldn't that be "Simon says"?
  10. #1360
    Jan 2011
    Far West Wimmera
    63
    4,049
    Maybe he wants to hang a sock.
    Maybe a stocking.
  11. #1361
    May 2011
    Murray Bridge S Aust.
    5,942
    Could be he wants to say "my Son can make anything"!!!!! Nice work by the way.
  12. #1362
    Apr 2009
    Horsham
    92
    You may be on to something there... It may have also been to get me to visit...
  13. #1363
    May 2011
    5,942
    Default ER 25 Collet Chuck
    In a previous post I said I was making an ER 25 Collet Chuck, well here it is I hope. By the way this is my first turning in about 20 years. Any C and C's welcome.
  14. #1364
    May 2011
    5,942
    Some more gear I've made for the shed.
    Taper turning attachment, this was made some time ago, to help make wheel cutters, photo of this will be in toy making section.
    45 degree block for band saw.
    Stop rod, storage area
    Swarf catcher, instead of swarf going on the floor, it now goes into a bin
    Mill tramming support, to stop front lifting slightly
    Tramming adjustment blocks, I found that I was getting a lot of sideways movement, this solved it
    Thanks to Treecycle for giving me destructions on how to load pics. Thanks Mate it was really easy.
  15. #1365
    near Rockhampton
    6,216
    A neighbour gave me a brass windmill pump to thread each end... Is 3 1/2" ID... I have always been meaning to make a pipe centre, but never got around to it...
    For a short term solution I made up this to fit into the live chuck I have for the tailstock... It is 125mm OD.... ground all over on the cyl grinder...
  1. latest little project
    By wayno60 in forum WELDING
    Last Post: 12th Jul 2008, 03:40 PM
