Page 54 of 202 FirstFirst ... 444495051525354555657585964104154 ... LastLast
Results 796 to 810 of 3020
  1. #796
    Sep 2011
    Ballarat
    65
    3,103
    Well done Bob,
    simple and successful, could it get any better.
    Phil
  2. #797
    Mar 2008
    nowra
    1,598
    I made a crank handle to hand crank my lathe It's made from 100 % recycled materials.
    Andre
  3. #798
    Nov 2008
    Perth WA
    6,459
    Quote Originally Posted by welder View Post
    Come on Andre, you're only telling us a quarter of the story. I can see a socket extension and a handle. How does it work?
    Bob.
  4. #799
    Nov 2008
    Perth WA
    6,459
    Quote Originally Posted by krisfarm View Post
    I originally made this impact driver tool changer back in 2009 and posted it here post #193. It has worked reasonably well but on occasions with one particular tool it sticks and I have to give the drive dogs a little tap with a brass hammer. I think the main problems are the impact driver cannot be held down firm enough and it is a bit small to dislodge the 40 series taper on this mill, it is also hard to control the amount of tightening.I felt it needed a redesign. I remember reading posts from DaveJ about his intention of fitting quick release tool changers to his mill, in his case two of them so I made contact with him, working on the theory that two heads are better than one. After going through all the issues Dave suggested fitting a Ball Thrust bearing my original set up had thick greased washers. I tried this it did improve it slightly but I still had the occasional hang up. Dave also mentioned that he had seen draw bars that were captured in place.
    It was time for another modification so I sketched up a new draw bar design and a thrust bearing housing that could be added to my existing design. This would enable me to change back if it did not improve the situation. After installing the new set up and giving it a test for the last week or so with all of my tooling I have had no hang ups. As the draw bar is now captured when undoing it, I have found that I can reduce the compressors line pressure down to 60 PSI instead of the 80 PSI of the original set up.
    A few photos and my sketch to help understand it. Thanks to DaveJ for his assistance. I have changed the impact drivers handle back to the original style as shown in the picture of the total assembly mounted on the top of the mill.
    Bob
    And while I'm at it....
    Your work is too good to be displayed in piddly little photos Bob. I don't know what you use as a resizer but large ( to fit a 1024 x 768 screen ) would go some way to doing it justice.
    Bob
  5. #800
    Apr 2009
    Ballina N.S.W.
    644
    Bob,
    Thanks, I used 600*400 as I thought I read somewhere that there is of eight photo limit, by making them smaller I squeezed nine in. Next time I will throw caution to the wind and go for bigger ones.
    Bob
  6. #801
    Oct 2008
    Wimmera
    51
    369
    My latest
    start with $200 bucks worth of 6061 aluminium
    add 10hrs worth of machining and you get a set of custom made triple clamps
    there for a custom bike a friend is making i will get some pic's of the bike once he has it together
    made a wood template to make sure the fitup was correct
    there are more photos of the process here
    cheers
    Harty
  7. #802
    Dave J Guest
    They came out nice, the blend on the curves came out great.
    Dave
  8. #803
    Nov 2008
    Perth WA
    6,459
    Certainly some work there Peter. Well done. The process photos reveal some of the painstaking effort involved.
    I have to get myself a Wohlhaupter, it's starting to look like I'm the only one without one.
    BT
  9. #804
    Sep 2011
    Ballarat
    65
    3,103
    Outstanding as usual Pete. Your mate must be rapt.
    Phil
  10. #805
    May 2010
    Lower Lakes SA
    58
    2,607
    Nice. Does the 10 hours include programming?
  11. #806
    near Rockhampton
    6,218
    Quote Originally Posted by Bryan View Post
    programming?
    programming? You mean it wasn't done with a hammer, cold chisel and file?
  12. #807
    Oct 2012
    Australia
    621
    Quote Originally Posted by harty69 View Post
    My latest
    there for a custom bike a friend is making i will get some picks of the bike once he has it together
    cheers
    Harty
    Nice work Pete. How did you index for the V cuts? they look tricky to me.
  13. #808
    Oct 2008
    Wimmera
    51
    369
    Hi Brian
    yep includes programming its the easy bit but doesn't include head scratching swearing and shoveling off 3/4 of a rubbish bin full of swarf
    the hard part was working out how to do it and maintain the correct steering angle as the frame is an old kawasaki 900 and the front end is off a gsxr 1100
    BT
    you defiantly need a Wohlhaupter it made this job a whole lot easier as 4 of the bored holes needed to be matched very closely and one is a h7 interference fit
    RC
    the hammer cold chisel and file are only used when we have to put it together
    cheers
    Peter
  14. #809
    Oct 2008
    Wimmera
    51
    369
    Quote Originally Posted by Brobdingnagian View Post
    Hi josh
    tricky would be one word for it
    there is a hint in this pic look for blue
    its a digital protractor there surprisingly accurate as a reference
    but the process was machine the flat in a specific distance then using a facing cutter with the head tilted to 31.7 deg step down and across to pickup the edge of the flat section
    this worked well and both sides are within .5mm
    then flip the part placing the head vertical again and laying the part in the vice and face parallel picking up the edge again as below
    because all the other machining is done to a specific dimension this worked well for this aplication
    cheers
    Harty
  15. #810
    Oct 2012
    Australia
    621
    Hi josh
    cheers
    Harty
    I did not pick up on the digital protractor... Very clever, I'm gonna put that one in the memory bank..
    -Josh
  1. latest little project
    By wayno60 in forum WELDING
    Last Post: 12th Jul 2008, 03:40 PM
