Results 271 to 285 of 3018
Thread: Your latest project
4th Oct 2011, 09:41 PM #271Member
- Apr 2011
- Brisbane
- 91
thanks guys,
yeah it is a polishing trick kraits, the top frame is mitred and welded as one piece, and the 4 legs butt welded on below, but the directional polish is done as if all the joins are mitred.
I grind down and blend the welds with a fiber sanding disc at around 3,000rpm on a variable speed grinder, then further polish/remove the swirl marks with non-woven type surface conditioning discs on the same grinder (attaches to a hook & loop pad, i found all that stuff at trade tools)
after that i take some shaft mounted surface conditioning wheels in a drill (100 grit followed by 180 grit) to give it the directional satin finish. the corners are masked off with thin sheet metal/shim stock/cut up bundy cans to get the mitre polish.
up very close theres still some slightly visible swirl marks around the blending areas and i'm thinking a few more polishing steps with a random orbit sander might get rid of them, before the directional polishing is done, but i'll have to try that out and see
Stu the last one was a birthday gift for a friend of mine- this current one is the first piece i've actually made for my place so it's nice to be able to keep it
17th Dec 2011, 07:51 PM #272Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
CXA dovetail tool holder for 25mm shanks.
[ame=http://www.youtube.com/watch?v=HY8wZlTKxJw]PC151949.AVI - YouTube[/ame]
17th Dec 2011, 08:29 PM #273Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
one again i would hardly call that rough handling. they are great. how long did it take you to make all theses.
well done. its hard to focus on a job that big. very impressive.
aaron
17th Dec 2011, 08:34 PM #274Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Nice job Bryan. Did you offset the dovetail for maximum support for the boring bar?
Phil
17th Dec 2011, 09:01 PM #275
Hi Bryan,
The 25mm tool holder production line is about to get underway I see, have you noticed much difference with the 25mm tool holder? Finish quality etc?
I had trouble with embedding a youtube video the other day, and I eventually put it down to the fact that it was a youtu.be url, which vbulletin's script didn't pick up, I should drop a note to the forum admins and see if they are aware of the issue..
Let me try something...
[youtube]http://www.youtube.com/watch?v=HY8wZlTKxJw&feature=youtu.be[/youtube]
Hmmm ...Ok, didn't work, but worth a shot I suppose... ok, what if I take off the "&feature=youtu.be"
[ame="http://www.youtube.com/watch?v=HY8wZlTKxJw"]PC151949.AVI - YouTube[/ame]
Bingo!
17th Dec 2011, 09:05 PM #276Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Worked for me ray
Actually the second one didn't. The one with all the 20%s.
Phil
17th Dec 2011, 09:08 PM #277
Hi Phil,
The second one worked for me when I deleted the &feature=youtu.be bit at the end of the url...
Did the first one work for you?
17th Dec 2011, 09:10 PM #278Most Valued Member
- Sep 2011
- Ballarat
- 3,103
First one was great.
This is on my phone
17th Dec 2011, 09:28 PM #279Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Ray, thanks, I edited my post with that fix. Have to remember that.
I haven't had a chance to use the holder yet. It won't be much of a comparison since it's the only insert holder I have, except for a parting tool. It came with the lathe and I'm looking forward to using it. But I only have one insert so I'll wait till I need it. If I like it I'll buy more.
Aaron, I've only made one so far. The black ones are cheapies from CDCO. I just included them for comparison. They only take a 20mm shank. I plan to make some more but they will be smaller. Most will take a 3/8 HSS bit directly.
Phil, I didn't put a great deal of thought into it to be honest. I just kind of make it proportional to the shank. And I didn't see any point having material hanging out the back doing nothing. When I came to the screw locations I had to make a decision.
Still have to find a way to make some nice adjusting nuts without a knurler. That works.
18th Dec 2011, 06:46 AM #280Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Hi Bryan,
What if you chucked a piece of round and turned it to suit the bore of one of your change gears then drill and tap a hole in the end to suit the thread in the nuts to be knurled. Slide the gear on then a short piece of tube to clamp the gear, screw a piece of all-thread into the tapped hole, next a washer large enough to pickup the short piece of tube then a nut to clamp the gear in place. Put the nut to be knurled on next and lastly a nut to tighten against that. Set up a single point tool and proceed as though you are making the markings on a graduated collar. Use a piece of flat to fit between a gear tooth and the lathe bed for indexing. Of course this is if you only want a straight knurl.
Hope you understand my description as lately I seem to be writing them from a parallel world.
Phil
18th Dec 2011, 07:18 AM #281Philomath in training
- 6,542
Bryan, would you like me to do a short length of bar 'pre-knurled' for you? As it's an adjusting nut concentricity is not vital, so I could do say 50mm of 25mm or there abouts bar for you if you like and then you can re-chuck to part off & finish.
I bought 4 secondhand Aloris BXA holders the other day and on one most of the height adjustment stuff is missing. The only thing worth saving is the round (knurled) knob, so if you prefer you can have that if you like (diameter 25mm) although condition is certainly 'used'.
18th Dec 2011, 07:40 AM #282Philomath in training
- 6,542
Just noticed something...
My first set of QCTP holders was a Shars set, probably from the same factory as your CDCO ones.They were a pain to adjust because every time the lock nut was loosened, the adjusting knob would move with the nut.
When I bought the CVA I got a second hand Aloris set for the tool post. They use a toothed washer between the knob and nut. The theory is that being keyed to the stud, the washer won't rotate and so the knob stays in the same position - it seems to work.
I haven't been able to successfully reproduce those washers but Aloris do sell the adjusting mechanism as spares. There is no agency in Australia but they do sell direct out of the US.
Attachment 191447
18th Dec 2011, 08:09 AM #283Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Thanks Michael & Phil (yes I did get the gist). I have a Cunning Plan. It involves a shaper and a rotary table. Actually similar to both of your ideas. Make a straight knurled bar and part off the nuts. Limited by how deep I can tap and how long I'm game to part. I do have some knurl wheels on order, and a straddle tool is on my list, but I do like the idea of having control over the spacing of the grooves. The shaper method will give that, albeit slowly.
PS: Michael that's a neat solution with the keyed washer. And a very kind offer. Let me see how I go.
18th Dec 2011, 08:41 AM #284Most Valued Member
- Sep 2011
- Ballarat
- 3,103
18th Dec 2011, 08:47 AM #285Pink 10EE owner
- 6,216
Excellent work Bryan....
So when are you going to make me a dozen CA holders for my lathe?Gold, the colour of choice for the discerning person.
latest little project
