Results 196 to 210 of 3018
Thread: Your latest project
30th Apr 2011, 02:31 PM #196Golden Member
- Apr 2009
- Ballina N.S.W.
- 644
Your Latest Project
Hi azzarock,
The design of the drawbar tool has been around for a long time, I made mine with long bush extension tubes as my operating handle is a fair way forward and down from the tool. The Diamond tool holder I made a couple of years ago and I like it and use it a lot, you do need good quality HSS bits for them, I use 10% Cobalt.
Bob
30th Apr 2011, 08:01 PM #197.
- 6,458
Neat idea and typically well executed Bob.
Can you still access the drawbar and use it manually in the case of a bit of late night milling. An impact driver and compressor would create some noise. How do you reverse the driver?
Bob.
30th Apr 2011, 08:41 PM #198Most Valued Member
BT,
That's what we call a butterfly gun. If you look in the second picture you'll see a pivoting plate with R and F. Push on one side forward, push on the other reverse. The Aluminum handle in the fourth picture pivots left/right to operate it.
krisfarm,
Did you consider just letting the gun be driven by the spindle full time(except when the quill was down)?
30th Apr 2011, 09:09 PM #199.
- 6,458
Obviously a tool I don't have Stuart.
30th Apr 2011, 09:19 PM #200Most Valued Member
"the" tool you don't have
30th Apr 2011, 10:16 PM #201Golden Member
- Apr 2009
- Ballina N.S.W.
- 644
Your Latest Project
Anorak Bob.-Bob
The rattle gun does make a fair bit of noise operating, I am experimenting at the moment with it. I have put range limiting screws on both sides of the "butterfly" so that I can control the amount of air on both cycles independently.Apart from limiting the noise I wanted to control the rate that the drawbar is tightened,at the current setting it does up slowly and the noise is greatly reduced and it does not overtighten. There is an independent torque adjuster on the tool as well the compressor pressure. I found you need to undo at a higher rate to achieve enough rattle effect to loosen the tool. The top part of the tool including the rattle gun just lifts off the two stainless rods with no tools required for manual operation.
Stustoys-Stuart
I do most of my milling with the quill locked in the up position and prefered not to have the rattle gun engaged as you would only be wearing it out and making more noise. My drawbar has around 25 mm of thread engagement into the tooling so if the drawbar was set up lower you would have to lift and hold up the entire assembly every time you change tools. To fit a new tool in I currently slip the tool in to the taper and engage the the two dogs at the same time ensuring the socket is engaged and hold it there and activate the rattle gun.Thanks for your interest.
Bob
16th Aug 2011, 07:36 AM #202Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
the big one
its a little differant from the projects ive seen on this site .but it is metal .me and my brother have been working on it for a while.(with help from lots of others.)
Attachment 179203 Attachment 179205
and then after about $5000 worth of paint.
Attachment 179206 Attachment 179204
Attachment 179207
now a engine
16th Aug 2011, 08:51 AM #203Most Valued Member
- 4,255
[QUOTE=azzrock;.me and my brother
[/QUOTE]
I see your mum n dad wasted their money...same as mine..but something they did drum into me was ......its "My brother and I"
seem to have plenty of room for such a largish project in that shed of yours
16th Aug 2011, 10:30 AM #204Most Valued Member
- Oct 2010
- 1,910
opps
ya my brother and i. na not really that much room. these take up all the room..
Attachment 179210
16th Aug 2011, 10:36 AM #205
Are you planning a trip to Fallujah?
Cheers.
Vernon.
16th Aug 2011, 10:41 AM #206Most Valued Member
- 4,255
see ..i knew you had a big shed
holy moly...which war ya going to?
16th Aug 2011, 10:41 AM #207Most Valued Member
- Oct 2010
- 1,910
na to hard to find cold beer
16th Aug 2011, 11:18 AM #208
Aaron, that Falcon is looking a treat, great project.
Not as much gloss on that Bushmaster
16th Aug 2011, 10:47 PM #209Dave J Guest
Life has got to be good with a car hoist and spray booth.
The panel van is coming along nice.
You don't see many around these days.
Dave
17th Aug 2011, 12:38 AM #210Most Valued Member
- Oct 2010
- 1,910
hi dave and fred.it is all good fun with the right gear. some thing really look forward to working on the van.but know i have a linishing wheel to fit to my grinder.
fred i sent you a mess the other day did you get it?
latest little project
