Results 2,146 to 2,160 of 3016
Thread: Your latest project
31st Oct 2018, 09:22 AM #2146Golden Member
- Vic
- 48
- 544
Hi Graham,
I bought that aluminium housing from Trash & Treasure for $5 a while ago. It has 60mm diameter internal for "T" connection so could be scaffolding or some sort?
I am using 1/4" universal drive on the inside to act as coupling. It is welded to the shaft and the shaft is welded into the chuck backing plate but I can undo the thread at the motor end if I need to take everything apart.
Regards,
TrongLast edited by jackaroo; 31st Oct 2018 at 09:30 AM. Reason: adding more info
31st Oct 2018, 09:50 AM #2147Senior Member
- Perth, Western Australia
- 67
- 362
I made a similar thing on the weekend, its very crude not as well made as yours.
The motor came out of an old mig, connected that to 30/1 reduction box.
In the pics its driving a set of rollers but I have a 8" 3 jaw I am going to set up so I can change the motor from one to the other.
I was really surprised by how much torque these mig motors have.
31st Oct 2018, 06:19 PM #2148Golden Member
- Vic
- 48
- 544
Hi "bts" your motor looks very similar to the wiper motor, I think it has worm gear inside too. I was going to use the 1:40 reduction gearbox too but that will be too bulky, the voltage regulator on the power pack seems to be working ok without the reduction gearbox. The bearing I have is double row, here is the "inside".
Regards,
Trong
31st Oct 2018, 08:27 PM #2149Senior Member
- 67
- 362
Looks good there Trong.
The motors do look very similar but going by the speed yours seems to go down to the gearing between the two must be completely different.
The mig motor runs from 7 rpm at 2 volts up to 218 at 38 volts. To fast for a welding jig at least for me and slow speed is very touchy to control.
The 30/1 reduction gets it down to 7.2 at 38v.
Rummaging around one of the junk boxes I found another box, 15/1. Very compact unit.
I had to see how it would go.
Checking rpm v`s voltage
Very good control from .5 rpm at 2v up to 15 rpm at 38v. It will probable suit my needs better if I can ever find the bits to build the rotating chuck.
Tony
2nd Nov 2018, 12:09 AM #2150Senior Member
- 67
- 362
Had a bit of a thought walking past the sandblaster this morning. So I bolted the motor and reduction box to the side added an extension shaft, a modified old bracket from something long ago to mount the gun and there you go semi auto sandblasting.
Ok semi auto is stretching it a bit but as luck would have it the wheel crept a bit from right to left as it rotated giving surprisingly good result.
This first wheel had been blasted years ago so it only had some surface rust on it, not a true indication so another was done.
Before
After
Shows some promise.
Tony
3rd Nov 2018, 11:39 AM #2151Senior Member
- Nov 2012
- Mid North Coast NSW
- 422
Wow r3292c, awesome work.
Would love to see details of your cnc lathe.
6th Nov 2018, 09:25 PM #2152Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Building a new stand for the Hafco AL330A, it stands 840 high, there's not much worse than a lathe sitting too low.
6th Nov 2018, 11:20 PM #2153Senior Member
- 67
- 362
The neighbour donated a wiper motor to blaster cause. (Patrol rear window I think)
Made up some very dodgy linkages and fittings to make a reciprocating (or is that oscillating) gun holder.
The motor drives a too fast so ended up with reasonably good cleaning on the inner and outer edges but streaky in the middle.
Anyway gives me some food for thought while it goes into the too hard bin for the moment.
7th Nov 2018, 03:29 AM #2154
Hi Bts,
If you can reduce the voltage to the motor it will slow down. A variable voltage PSU is ideal for this. Alternatively you could try a side light or other vehicle bulb in series with the motor, which will reduce the voltage and thus slow the motor down.Best Regards:
7th Nov 2018, 07:46 AM #2155Diamond Member
- Aug 2006
- 1,105
Try a PWM motor controller they are cheap and easy to work with. https://www.ebay.com.au/itm/New-DC-6...DedP:rk:8:pf:0
Wouldn't mind seeing a video of this in action.
7th Nov 2018, 12:36 PM #2156Senior Member
- 67
- 362
Power to both motors are controlled by the DIY variable control units off to the lower left.
Black box -40-0-+40 volts, 8 amp. The other -24-0-+24 vdc, 3 amp. They where built for my Audio building. When things progress I will build some more suited units.
The motor controlling the gun movement is down to approx 2.5 volts, any less and the motor will stall.
At 2.5 v it takes approx 14 seconds to do a complete cycle.
Taking out non-traveling time, surface travel speed through the arc is approx 40 mm/sec. In some manual tests I have done 10 mm/sec surface speed seems to give good results. Of coarse this all depends on what you are trying to remove.
I pulled the cover off the motor//box last night to see if I could fit a reduction box, it will be easier to find another mig motor or a wiper motor with out the recip conversion on it.
Tony
7th Nov 2018, 07:44 PM #2157Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
It does the Job, think I'll add a shelf in the middle as well as the bottom though
7th Nov 2018, 08:37 PM #2158Diamond Member
- Aug 2006
- 1,105
Should do the job, are you going to add any levelling feet to it? Also could add some tooling storage while you are at it
7th Nov 2018, 09:57 PM #2159Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
I might add the levelling feet at a later stage, I could definitely use some extra storage under the lathe
9th Nov 2018, 08:28 PM #2160Pink 10EE owner
- 6,216
Going to make a spindle adapter for my little G&L 25 horizontal borer, It will just be a lump of cast iron with T-Slots bolted onto the spindle nose so other things can be attached.
Got a piece of 210mm OD round cast iron, I ordered a 75mm long piece, they sent me a piece 100mm long one side and 125mm the other. They must have cut it with a hacksaw to get it so crooked.
Have cleaned it up a bit and drilled a 2" hole through the centre. Got a bit more efficient, while I was facing off the crooked cut, I drilled the 2" hole.
20181109_181912.jpgGold, the colour of choice for the discerning person.
latest little project
