Page 141 of 202 FirstFirst ... 4191131136137138139140141142143144145146151191 ... LastLast
Results 2,101 to 2,115 of 3016
  1. #2101
    Aug 2011
    4,779
    Hi Kryn,
    Im sure it could be done but it would be alot of work for a small gain. I now have a bridgeport clone (Pacific or Lagun in US) which has these features and i will soon be using it for all my work.
  2. #2102
    May 2011
    Murray Bridge S Aust.
    5,943
    As I said, it was just a thought, not realising you have a decent mill.
  3. #2103
    Aug 2011
    4,779
    I managed 0.0003" Josh improved on that a touch! //metalworkforums.com/f65/t1664...84#post1615984
    Thats insane. I really didnt know you could get to that level of accuracy without a controlled evironment.
    Neither me or my SG are capable of those measurements. I think ill have to be satisfied with what i have. I do have ring envy though!
    Thanks for the link Bob!
  4. #2104
    Nov 2007
    melbourne australia
    3,228
    I managed to get it flat (according to my 2um DTI) to within 0.008mm.
    Isn’t that very close to the 0.0003” that Bob got?
  5. #2105
    Aug 2011
    4,779
    Hi Jack, yea its pretty close but when you look at what Josh achieved at 0.000025mm its an order of magnitude better again!
    I think i can improve on my results if i wanted using the SG and definately improve it if i handscraped it but for what it will be used for its fine for my use.
    Sometimes its fun and rewarding achieving such levels of accuracy even if its not entirely necessary!
  6. #2106
    Nov 2007
    melbourne australia
    3,228
    My mistake Simon. I didn’t realise you were referring to the tramming ring in the video. I should pay more attention!
  7. #2107
    Nov 2010
    Gippsland Victoria
    733
    Default Rotary Table : WIP
    January this year : I was lucky to be first online after Joe88 offered a kit for building a rotary table //metalworkforums.com/f223/t201...nished-project 98% complete only a couple of minor jobs to do.
    Finally got around to it today, bored the hole for the wormscrew.
    Yes, it is egg shaped, because I bored the hole in the wrong place and had to 'odge it across a bit.
    Did that fairly carefully and although hole is egg shaped the screw is a snug fit between wormwheel and "other side" of bored hole. Put a screw through the block and into the collar to secure the collar and make sure the wormscrew couldn't back out of the hole.
    18 turns of the handle turns it 360 degrees =20 degrees per revolution.
    All I have to do now is scratch the graduations on the knob.
    How does one lubricate these things ? Is it a puddle of oil in the bottom of the bored hole or a heap of grease ?
    Made a tiny little swarf grabber from a piece of dowel, a magnet and a dried up permanent marker - far far better than simply flicking the mess somewhere else with a paintbrush. Just as easy to pick it with the grabber and dump it in the bin.
    Happy Winter to you ....... WormscrewAndBlock.JPGLoosely Assembled.JPGAnglePlateIndex.JPGMiniSwarfGrabber.JPG
  8. #2108
    Nov 2010
    Gippsland Victoria
    733
    Default Graduated the Knob
    Ongoing Rotary Table WIP (promised Joe88 I'd write it up as a WIP)
    1. 120 graduations on 1.75” knob
    First few photos are the graduating setup – used the CGTK website to calculate and print the dividing guide, laminated it then mounted it between the chuck and a thin Aluminium plate. Didn’t lock the spindle -was only doing scratches not machining, 60 degree threadcutting bit mounted on boring bar at full extent to do the scratching. Pushed the tool in 0.050”after touching workpiece.
    Mistakes Made :
    Lines are a bit thick ? Try using a sharper cutting bit next time > 30 degree instead of 60 ?
    Bit too gung ho winding the carriage and slowly shunted the carriage depth stop along the ways and the lines slowly got longer
    Decided to go around again and extend the major lines but it looks a bit daggy and obvious – do it once and do it properly – spend a bit more time thinking at the start.
    When I assembled everything and tried it I noticed the main table was a sloppy fit on the subtable, and this was contributing to backlash,
    2. Shimmed the main table to fit tight on the subtable.
    a couple of shims identified that the hole in the subtable is 0.008” oversize – lucky ! My Solo tin shims are exactly 0.004” so I cut a strip of Solo tin and wrapped it around the stub of the main table for a perfect fit, I didnt know what to do and faffed around for a while.
    …...was a very awkward job…... because of limited room to work inside the hollow part of subtable - see photo – is there a standard way of doing this ? Got it done eventually.
    Almost but not quite zero backlash now. Next job mount block onto base plate or mount the block straight onto mill table - Not sure what is best here. Need to ponder.
    Its got one flat side so I can tip it on its edge and use it as a dividing head, I think I can mount dividing plates if I take the graduated knob off.
    Apologies for large filke sizes, have just changed to Linux and the screen captur makes very big files compared to WIndows
  9. #2109
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,541
    Quote Originally Posted by steamingbill View Post
    Have a look here //metalworkforums.com/f65/t1984...35#post1898835
    It shows an engraving device that I made up and have used for several jobs. The key thing for you though is that it uses some strips of material to control the length of the lines. You might be able to devise something that uses that same idea to get all the lengths the same.
  10. #2110
    6,439
    Hi SteamingBill,
    Nicely done ! A rotary table is a very useful addition to the workshop.
    Re Linux, I use "KolourPaint" to edit my pictures.
  11. #2111
    Jul 2008
    near Warragul, Victoria
    3,718
    I made a scraper . Hope it works out OK , I followed Stefan Gotteswinter's tutorial . I found the wooden handle in the op shop, two for a dollar , I think they are bed end ornaments or similar !
  12. #2112
    Apr 2009
    Horsham
    92
    Well, I don't come here very often anymore but thought I should post about my latest project. Back in March 2012 .RC. asked about Magnabend hinges as he wanted to make a folder. I was already doing the same... fast forward to August 2018 and I finally have it finished. Yes 6 1/2 years later it's (mostly) finished.
    I have documented the process in pictures on my website here (link). Most of the pictures do have a brief description of whats going on in case you would like to know what in the world I'm up to.
    I used the information available on the Magnabend inventors website here (link) and have been corresponding with him over the past few years to help the project along. He was very helpful and without his help I doubt I could have gotten to this stage.
    Jayson
  13. #2113
    Aug 2011
    4,779
    Nice work Jayson and from the pictures there was a lot involved in making the Magnabend.I like the decaling you did!
    Edit: I assume many of the parts (including the hinges) were made on your CNC mill. Did you write the DFX files yourself or did the dude from Magnabend supply all that for you? It was nice of them to help you.
    Also, bit off topic but in a couple of months I should receive my surface plate. I will be scrapeing the Macson shaper I bought from you.
    Cheers mate, great to hear from you.
  14. #2114
    Apr 2009
    Horsham
    92
    Hi Simon,
    I do enjoy descaling metal like that ...
    Almost all the parts were made on the mill. I was supplied a scan of the original drawings of the hinge parts that I then redrew and modeled in cad.
    CNC makes things repeatable but not necessarily faster in my case. Each hinge took roughly 11 hours to make. I have no idea where the time went but it sure added up quickly. Hinges can be purchased for just under $300 each and these were by far the most time consuming part, but if I were to do it all again I would still make the hinges...
    It was great that Alan , the Magnabend inventor, was willing to help, it sure mage things easier.
    Good to hear your about to start on the Macson, I will let Harty (that you purchased it from) know )
    Jayson
  15. #2115
    Aug 2006
    1,105
    Sure looks like an interesting project, you have done a great job with it. Is there a copy of of the hinge drawings available online?
  1. latest little project
    By wayno60 in forum WELDING
    Last Post: 12th Jul 2008, 03:40 PM
