Page 110 of 202 FirstFirst ... 1060100105106107108109110111112113114115120160 ... LastLast
Results 1,636 to 1,650 of 3020
  1. #1636
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,104
    I've just had "Why can't you make one of those, it would look lovely in the garden"
    Oh dear.... now you will have to find a large face plate
    Cheers, Joe
  2. #1637
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    This one is not big enough for it's own thread...
    This weekend was 'bitty', with lots of little bits and pieces that needed doing. Among them was a memento for one of the hydraulic fitters at work. The leading hand asked if I could do something as everyone else was busy. Here's the result -
    An old piston (with fake seals fitted) and a portion of rod tastefully turned into a bottle opener. It may even come in handy as he is going to the UK where they haven't caught onto screw top bottles yet. Weighs just over 600g (and that's after I've trimmed bits off here and there) so not a light weight item but certainly one of a kind.
    Now I suppose I'll have to embark on an extensive testing program just to check on it's long term durability.
  3. #1638
    Oct 2008
    N.W.Tasmania
    1,407
    Great job Michael, but I hope that your friend doesn't try to take it in his cabin luggage when he travels overseas, the security personnel would likely see it as a high tech caveman club and say , not on this aircraft.
    Rob.
  4. #1639
    Feb 2005
    Tweed Valley
    73
    27
    Quote Originally Posted by Petip View Post
    I found a 600mm face plate, don't have a lathe to suit, so thought l'd make a table. I like the idea of being able to stand up straight or sit down when l weld so made the height adjustable (screw). I also thought it would make a good coffee table for the back patio - wife not so keen though
    cheers
    Peter
    My wife reckons it's OK. Great idea for both uses. In future I maybe won't pass up on those óversize' auction items.
    Bill
  5. #1640
    Oct 2009
    Upwey VIC
    187
    Default Change Gears
    Just little project.
    I made three new change gears for the lathe, to fill in some gaps that should allow some more accurate imperial threads on the metric C6,
    The gears are 27T, 54T and 72T.
    I indexed the gear blanks using my cheap 4" rotary table, which has the unusual ratio of 36:1, which made it easy to do the 54T (2 turns of the handle and cut 18 times, move 2/3 turn, 2 turns of the handle and cut 18 times, and move 2/3 turn, 2 turns of the handle and cut 18 times) and the 72T (1 turn of the handle and cut 36 times, move 1/2 turn and 1 turn of the handle and cut 36 times).
    The 27T gear was then cut on the direct indexer using every second tooth of the 54T gear.
    I had a spare blank for the 72T gear , on which I made a mistake with the indexing. I can use this blank for another gear of less than 68T sometime if needed.
    For some reason I cannot upload pictures at the moment...
    Andrew.
  6. #1641
    Jan 2004
    Mackay North Qld
    6,446
    Quote Originally Posted by mahgnia View Post
    Andrew.
    Me too ! If any one else has had the same problems today let me know please .
    I get them up and a red spot appears at the side of the pic ready to upload. A click on it indicates an error message.
    The same pics can be uploaded to another forum without problems.
  7. #1642
    near Rockhampton
    6,217
    Seems to work here.
  8. #1643
    Jul 2008
    near Warragul, Victoria
    3,723
    Default Not me
    Pics won't upload for me ..been trying without success
  9. #1644
    near Rockhampton
    6,217
    Instead of using manage uploads. I would also try the upload picture int he toolbar above where you write a reply.
    Also uploading pictures requires adobe flash. Make sure it is up to date and has approval to run scripts if you are using something like noscript
  10. #1645
    Jul 2008
    3,723
    Default uploADS
    Something has changed , yesterday the forum was off line and since it came back on, the pics will not upload.
    I tried the image upload in the toolbox , but still no go.
    I have been using the pic uploader without problems for years, don't know why but it all of a sudden is not working
  11. #1646
    Jan 2011
    Far West Wimmera
    63
    4,049
    I use 2 Flash Block addons and have no trouble uploading pictures normally. I detest useless videos auto loading on web pages.
  12. #1647
    near Rockhampton
    6,217
    Yes it no longer works for me either.
    The error is #2038 is any admins are reading this. Does not seem to be that uncommon https://www.google.com.au/search?q=vbulletin+error+2038
  13. #1648
    Oct 2009
    Upwey VIC
    187
    Andrew.
    Pics working now!!!
    Andrew
  14. #1649
    7,188
    Yay
  15. #1650
    Feb 2013
    Laidley, SE Qld
    1,039
    Default Replacement for a cast iron radiator fitting
    My current car project is a 1935 Hudson, a cast iron fitting on the top radiator tank had turn into lace filigree. I thought about fabricating a replacement but as I had a suitable piece of steel I decide to machine it.
    There is a 2.25" x 16 tpi thread, a pattern of 5 small tapped holes and 6 mounting holes, apart from getting those 3 items right no great accuracy was required, a lot of thought went into the order in which each step was done. 10kg of steel whittled away to 1.4kg.
  1. latest little project
    By wayno60 in forum WELDING
    Last Post: 12th Jul 2008, 03:40 PM
