Page 10 of 202 FirstFirst ... 567891011121314152060110 ... LastLast
Results 136 to 150 of 3020
  1. #136
    Jul 2010
    9,088
    Came up heaps better than my toolmakers clamp RC. Mine is made out of 1/2" black bar, with two slot head screws, no taper. Very rough, my excuse is I didnt have a mill at the time. The truth is more likely I'm a little to lazy sometimes.
    Just one pick, why did you make the thin part of the threading tool so long? Its got to be about 40mm doesnt it?
  2. #137
    near Rockhampton
    6,217
    It is to reach into the part when doing small diameter threads...It is impossible to cut small threads with my insert tool as it fouls on the live centre once you get below 10mm or so...
  3. #138
    Apr 2009
    Ballina N.S.W.
    644
    Default Your Latest Project
    My workshop bench space was starting to get a bit overcrowded over the years and a lot of machines could be better located, so I decided to build this portable grinding station so that I free up some space and could easily wheel it out of the shop away from my lathe, mill,drills etc and not cover everything with abrasive dust. I made up the belt sander from pictures of others I have seen on the net.I have made up the 200 mm diameter wheel bar and the adjustable table attachment bar as can be seen in the photos and plan on making another attachment bar that can handle an assortment of smaller wheels for grinding tubing. I left one side of so that the insides are visable. A few photos will make it clearer.
    Bob
  4. #139
    Nov 2006
    Heidelberg, Victoria
    79
    2,074
    KF,
    Very well done, what a great idea. I particularly like the bench grinder tool rests. I presume they are made of aluminium with milled rebates. Puts my Chiawan grinder tool rests to shame.
    Ken
  5. #140
    Jul 2010
    9,088
    Nice work Bob, it looks great.
    lol You had me clicking through the pictures until I realised you have two different "heads?" for the belt sander. I'm going to make one of those one of these days lol
    Is the adjustment to make the belt run true on the top roller?
    Only problem I can see is that the diamond wheel will stop you from moving the table in once the wheel wears down a bit.
  6. #141
    Apr 2009
    Ballina N.S.W.
    644
    I split the photos into two lots
    Bob
  7. #142
    Jun 2008
    Victoria, Australia
    74
    5,080
    Hi Bob,
    Beautiful work, looks very professional, nicely thought out. I like the idea you can roll it all outside and keep the grinding dust away.
    I can see a number of clever idea's there, the diamond cup wheel on the side of the bench grinder is one idea I'm going to have to pinch.
    Congratulations, nice job.
  8. #143
    cookie48 is offline Old Fart (my step daughters named me)
    Sep 2010
    Mallala S.A.
    76
    50
    What great build. Some very good ideas there.
  9. #144
    7,188
    That looks great!
    Where did you get the pillow blocks and bearings?
  10. #145
    Apr 2009
    Ballina N.S.W.
    644
    Thanks to all for the compliments.Now to answer the questions raised.
    Neksmerj. The tables are made out of 12.5mm Aluminium plate that I had left over with a common groove machined in them all.
    Stustoys. The belt tracking is done on the top idler wheel, I machined a one degree taper either side of centre on that wheel. That is plenty of taper and adjusting is very easy, I find you do not need it much as the belts run pretty true. The adjuster screw is shown in photo 290.
    Bob L. The bearings are just standard of the shelf ones that I picked up at my local bearing outlet
  11. #146
    Dave J Guest
    Very nice job and well thought out Bob.
    Looking at the wheels, do you think bigger wheels would be better to get over the paver's?
    Keep up the great work.
    Dave
  12. #147
    Apr 2009
    Ballina N.S.W.
    644
    Dave J,
    Dave as usualy you are very observant.The wheels are 100mm diameter and work OK, they were ones I had on hand from the dolly for my mill and I wanted to give them an additional use, I had to make up a set of brakes for two of them as you can see in the photos. If needed I can swap them back to the dolly with not too much effort. If I did not have these on hand I would of selected 150 mm diameter wheels that as you know would roll easier but need more room to manoeuver.
    Bob
  13. #148
    Nov 2008
    Perth WA
    6,459
    You have done a superb job, Bob.
    It's the manifestation of a whole bunch of ideas that, unfortunately, a lot of us might only have ever thought about.
    Show us more of your work.
    Bob T.
  14. #149
    Apr 2009
    Ballina N.S.W.
    644
    Anorak Bob,
    Thanks for your compliments on my grinding station, I have been admiring your work as well. The way you recently bushed your pulley is exactly how I would have done it, I had a post ready to send but had internet problems and by the time I got that sorted you had done, nice machining as well.
    Bob
  15. #150
    Nov 2008
    Perth WA
    6,459
    Bob,
    I'm going to rip off your adjustable grinder rest design. Is there anything that you would change if you were to do it again?
    Bob T.
  1. latest little project
    By wayno60 in forum WELDING
    Last Post: 12th Jul 2008, 03:40 PM
