Results 1 to 4 of 4
Thread: tee slot size
24th May 2010, 10:53 PM #1future machinist
- Mar 2008
- nowra
- 1,598
tee slot size
this might sound like a silly question but how do you measure the size of the tee slots on a mill as i need a clamp kit but not sure what size?
24th May 2010, 11:03 PM #2
Not at all , here a chart of imperial tee slots nuts.
J.W. Winco, Inc. - Standard T-Slot Nuts
and a chart for metric doovers
T-Nuts.com - Machine T-Slot Nuts, Metric (6-18mm)
Kev."Outside of a dog a book is man's best friend ,inside a dog it's too dark to read"
Groucho Marx
24th May 2010, 11:10 PM #3Diamond Member
- Sep 2006
- Mallacoota,VIC,Australia
- 53
- 1,010
HI,
It is quite easy, You just Measure the Table Slot (the Slot at the table surface not the lower bigger slot). For example if you if You measured 14.15mm You would need to buy some 14mm T-nuts. here is a Weblink that should Help: https://www.machineryhouse.com.au/Pr...stockCode=C086
and another Weblink: J.W. Winco, Inc. - Standard T-Slot Nuts
I hope they Help.
All The Best steran50 Stewart
25th May 2010, 05:38 PM #4future machinist
- Mar 2008
- nowra
- 1,598
hi thanks for the help i went to mike moyles this afternoon and bought a clamp kit and they had a second hand one for $70 dollars so a done deal ps the tee slot was 5/8
Guide to size of electrode and bead size
By Tiger in forum WELDINGReplies: 4Last Post: 10th Jul 2009, 11:45 AM
