Results 1 to 15 of 18
Thread: Flattening a steel plate
23rd May 2010, 10:04 AM #1Golden Member
- Feb 2010
- Ballina, NSW
- 900
Hi Everyone,
I was lucky enough to score a 900x600 plate of 10mm steel gratis. Great I said to myself - that's the top for my new portable welding table. Obviously I'd like it to be dead flat, but it's got a slight bow in the one of the long edges of about 3mm.(the other 3 edges are good)
I've tried a few things to flatten it out, including parking the 4wd on it with support shims in strategic places. If deflected nicely, but sprang back exactly when the weight came off. Haven't got an oxy set. I'm now considering running a few weld beads over the back of it to pull it into line.
Any other ideas (or tips on weld placement)?
thanks
- Mick
23rd May 2010, 10:45 AM #2
A BFH- big flammin hammer- judiciously applied at the correct spots will sort that pissy little bow out.
Using chalk and a straight edge-long ways and cross ways, plot the area out and wallop the high spot while the plate is supported on a couple of 4 x 2 s
A big sledge will do it if handled correctly.
23rd May 2010, 04:23 PM #3Golden Member
- Mar 2010
- Nth Qld
- 687
25th May 2010, 06:03 PM #4Senior Member
- Aug 2007
- 292
In contrast to the big beater method that bends the plate from the convex side in the same way you tried with your truck. You can hit the concave side with a ball peen hammer lightly a whole bunch along the length. It stretches the surface of the metal on that side which gradually flattens the plate. if you have access to a shot peening machine (type of sandblaster) you can do the same faster. Please note it will be more difficult, if at all, to achieve if the steel is hardened. Or go find a bigger truck.
Pete
25th May 2010, 07:45 PM #5Golden Member
- Feb 2010
- Ballina, NSW
- 900
Peter - Interesting ! - didn't know that could work, but probably beyond my patience levels. thanks for thinking about it though.
Grahame/Graziano - thanks. I gave it a few wacks this arvo and got it pretty good, so job done.
I have to admit I'm a bit disappointed though - I was expecting suggestions involving a lot of finesse, fine tuning, straight edges, feeler gauges, clamping, hydraulic jacks and the like. Although Grahame get's extra points for the spiffy diagram.
Do ya reckon the welds on the back would've worked? - Mick
28th May 2010, 10:00 PM #6Senior Member
- Sep 2009
- West OZ
- 151
In a word - maybe!
Lately I have been building lots of large frames (upto 1200mm length sides) out of different sized RHS(50x50, 25x25, 50x25, 35x35, etc).
When ever I do a "T" joint - butting one tube into another - the top part of the "T" always bends toward the butted piece.
If I need it neat I put the same amount of heat(length and duration of weld) on the diagonally opposite corner/side, let it cool, and then grind it off. If you are accurate in the amount of welding you do, the RHS straightens up perfectly.
Whether this would work on a solid sheet of steel I cant be sure - but I think it would. I think a thick sheet of steel would act the same - pretty much two sides of an RHS without the gap in the middle. Thinner sheets might work differently - much less heat would be required if you were trying to distort/straighten steel instead of welding it.
My 2c.
29th May 2010, 03:59 AM #7Senior Member
- Apr 2008
- 269
Bent plate
Bloke
U have one of them Kangaroo Jacks, use that. Take the bolt off the end and the plate, take the jacking bit off and turn it around. becomes a BIG MIGHTY CLAMP. I had the same problem, made a steel bench for my workshop out of RHS, got the plate cut to size to fit, get it home and it has a big dip one side, big bow the other. Scratched me head then remembered when I bought the jack, u can turn them around to become a clamp. Lucky I have two jacks.
I clamped the plate to the top bow up, then clamped the two jacks to the bench. Had my Boilermaker nephew do all the welding with the stick welder, a few whacks along the way helped too.
Is good, is flat.
DD
29th May 2010, 10:53 AM #8Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
Anything wrong with welding it to the table frame? You could put on some big weights, then weld a few runs from underneath to hold it flat.
Jordan
29th May 2010, 09:50 PM #9
Cut some L shaped cleats and weld them to the plate so they stand over the frame , then you drive a wedge between the cleat and the frame and the plate gets pulled down to the frame .Then weld the plate to the frame .Remove the cleats when finished.
Kev."Outside of a dog a book is man's best friend ,inside a dog it's too dark to read"
Groucho Marx
29th May 2010, 10:52 PM #10
Dog and wedge?
30th May 2010, 02:55 PM #11Golden Member
- Feb 2010
- Ballina, NSW
- 900
welding table
I made the top frame out of 50 x 25 RHS and was worried that the plate would just bend the frame if I welded it up under load. Also I figured if I could get the plate flat first then I could just square the frame etc up easy by building the table upside down from the plate up. I did try all sorts of clamping and weights, but didn't have a good surface to wedge against - so resorted to the sledgie.
Here's the table made up - nice to have a little table to roll around where needed. I'll probably a little rack or drawer later for bits and pieces. Cheers - Mick
31st May 2010, 01:10 AM #12danielson
- Dec 2009
- broadford
- 63
- 213
1st Jun 2010, 08:31 PM #13Golden Member
- Feb 2010
- Ballina, NSW
- 900
1st Jun 2010, 09:17 PM #14
2nd Jun 2010, 12:01 AM #15Golden Member
- Mar 2010
- Nth Qld
- 687
I used welds to straighten a 4.2m length of 5mm thick 100x50mm RHS that I'd welded eleven purlin brackets onto. I'd welded the brackets on one side and the bow was pretty noticeable when I'd finished, so I turned it over and used the stick welder to make a hot wide arc with a large air gap, this used very little filler rod and ran it side to side to give about a 10mm wide line opposite the bracket welds.
In other words it deposited little filler rod but did heat a 10mm wide strip but the same length as the welds on the other side to the welds. I started opposite the middle bracket then went along and did opposite every second bracket working towards both ends out from the middle. By the time I reached the ends and let it cool between welds it had been pulled very straight. Also it was hardly noticeable after painting.
Melbourne - Availability Of Steel Metal Plate
By Metal Head in forum METALWORK GENERALReplies: 2Last Post: 15th Jan 2009, 08:38 PM -
Turning a circle from thin plate steel
By BobL in forum METALWORK GENERALReplies: 2Last Post: 1st May 2008, 09:49 AM
