Results 16 to 30 of 37
Thread: HM52 collet sets
3rd May 2010, 01:53 PM #16
Hi Eskimo,
The NT30 ER32 collet chuck is here on the CTC website.
ER32 NT30 COLLET CHUCK #B59
3rd May 2010, 02:15 PM #17Dave J Guest
RC,
I dont like over loading my machines, but using an indexable end mill with 2 tips, cutting a slot, I can take a 1mm DOC in steel with no problems or strain, any more the machine complains a bit.
Ray,
I almost answered the same, but then realized that he was talking about CDCO not CTC. Looks like it caught both of us out.
Dave
3rd May 2010, 02:45 PM #18
3rd May 2010, 03:24 PM #19Pink 10EE owner
- 6,216
3rd May 2010, 05:35 PM #20Most Valued Member
- 4,255
Heine at CTC caught my order and its now changed to ER32's
Thanks RC and Dave
3rd May 2010, 06:05 PM #21Dave J Guest
The end mill is like the one in the link below.
I would recomend these end mills to all you guys, you get value for money and they cut great.
20MM AKEN INDEXABLE ENDMILL & 10 PCS MITSUBISHI CARBIDE INSERTS #B35
Dave
3rd May 2010, 08:59 PM #22
3rd May 2010, 09:51 PM #23Senior Member
- Canberra
- 184
Have you tried a roughing cutter? I've been using these, 4 FLUTE HSS M2AL ROUGHING ENDMILL CUTTER - METRIC #G71 and found them to be really good quality. If you don't use a coolant pump these more expensive M2AL cutters are worth the extra cost, they're similar to cobolt HSS.
The difference that roughing cutters make on a small machinie is really amazing. It is a complete game changer.
3rd May 2010, 10:36 PM #24Senior Member
- Sep 2007
- Newcastle NSW
- 77
- 155
I have the Clarkson Autolock system on my mill. The collets can be obtained in Metric and Imperial. The end mills,slot drills etc screw into the collet and cannot work their way out during use. Occasionally the chuck & collets come up on Ebay, more often from UK.
Russell
5th May 2010, 10:31 PM #25Golden Member
- Apr 2009
- Ballina N.S.W.
- 644
HM 52 Collet sets
Hi Richard,
I have been away and just noticed your picture of your ER40 collet chuck. My recently purchased from CTC Tooling ER40 chuck is a lot shorter, in fact it is slightly shorter than my ER32 chuck. I know they make these collet chucks in a variety of lengths and we do need short ones for the smaller style machine that most people seem to have. Attached is a photo of the both.
Regards Bob
6th May 2010, 08:54 AM #26Most Valued Member
- 4,255
6th May 2010, 10:09 AM #27Pink 10EE owner
- 6,216
6th May 2010, 10:38 AM #28Most Valued Member
- 4,255
2nd Jun 2010, 03:36 PM #29Pink 10EE owner
- 6,216
Did you get the Collet Chuck OK??
I ordered $300 worth of goods from CTC a couple of weeks ago and it has just turned up today (end mills, and other milling cutters mostly).. I got a full ER32 collet set but did not want to order the chuck until I saw yours..
Can you post a picture of your chuck as all???
4th Jun 2010, 08:52 AM #30Most Valued Member
- 4,255
HM52 CNC Conversion
By RayG in forum METALWORK GENERALReplies: 187Last Post: 9th May 2016, 07:55 PM -
S/h hm52
By Dave J in forum METALWORK GENERALReplies: 0Last Post: 23rd Apr 2010, 06:35 PM -
Hafco Hm52 on the fritz again
By Retromilling in forum METALWORK GENERALReplies: 25Last Post: 12th Aug 2009, 11:14 AM
