Results 1 to 9 of 9
Thread: Dangers of Acetylene
8th Dec 2009, 02:36 PM #1Most Valued Member
- Charlestown NSW
- 1,673
Some of you have probably already seen this, but for those who haven't, a graphic reminder of how dangerous acetylene can be.
regards
bollie7
8th Dec 2009, 02:59 PM #2
Yeap, Woodwould put that up the other week
The result of a leaking acetylene cylinder...Cheers
DJ
ADMIN
8th Dec 2009, 03:02 PM #3
So now he has an 'open top tourer' instead of a van, plus an aluminium ladder that will be very useful for climbing around corners....
Remind me not to live next door to a plumber.
8th Dec 2009, 08:27 PM #4Most Valued Member
- Charlestown NSW
- 1,673
8th Dec 2009, 09:37 PM #5
The explosive range of acetylene is very wide,Can't remember the original figures but in the order of
97% acetylene /3% air to 90% Air to 10% acetylene.
I got this at a presentation from an in plant firechief.
cig used to have a samples of stuff that had been in fires and the like.
I have had a very healthy respect for the stuff ever since.
This is why they give it a pungent garlic like odour. The plumber may have missed the odour but I don't think he had long,as the light triggred the blast when he opened the door on the van.
8th Dec 2009, 10:13 PM #6Diamond Member
- Sep 2006
- Mallacoota,VIC,Australia
- 53
- 1,010
HI,
Strewth I knew the stuff was Explosive, but not that Explosive.
All The Best steran50 Stewart
8th Dec 2009, 11:18 PM #7
I think its actually closer to an explosive range from 3% to 97% in air - it's got the widest explosive range of any gas.
Not to mention that it forms copper acetylide (a heat and shock sensitive high explosive) when in contact with copper (I think you'd find a fair bit of copper in a plumber's van!).
9th Dec 2009, 02:28 AM #8
9th Dec 2009, 10:16 AM #9Most Valued Member
- Charlestown NSW
- 1,673
Sorry mate, my remark about wood working was never intended to taken as having a go at you. which is why I put the smiley thingo on the end. If you took it that way I do apologise. I have total respect for people who make things from wood, as, apart from basic stuff like wall framing, anything else is a bit of a black art to me. As far as making allowances as you are a woodworker, I actually meant that, but not from a nasty point of view. If I said to you or another woodworker that I didn't know much about wood working but I was trying to learn and that I wanted to buy a wood working tool I would expect the woodworker to make allowances for me. Simple as that.
regards
bollie7
New use for Oxy Acetylene set?
By neksmerj in forum METALWORK GENERALReplies: 24Last Post: 4th Jan 2009, 10:27 PM -
filling up Acetylene Oxy set
By timbo123 in forum METALWORK GENERALReplies: 8Last Post: 27th Jun 2007, 01:59 PM
