Results 1 to 5 of 5
Thread: Holders for milling cutters
10th Oct 2009, 11:58 PM #1
I have a mini mill which has an 3 Morse taper in the spindle. I also have an E32 Collet chuck with 3 collets that accomodate 3 sizes of milling cutters. Over the years I've picked up second hand milling cutters from flea markets etc. Some have screwed shanks, some plain shanks. My question is what is the most economical way to go to use these collets? How would they go in a drill chuck? The cutters I have would used be sparingly so I prefer not to go and spend $30 each for a collet that I wouldn't use all that much.
11th Oct 2009, 01:16 AM #2Golden Member
- Cairns, Q
- 666
Tiger,
Although it is often done, holding end mills in a drill chuck is not a particularly good idea - many drill chucks do not run very true, and unlike drills, the end mill shanks are quite hard. This allows them to slip in the drill chuck, and can sometimes lead to damage to the chuck jaws.
For occasional use it is probably better to make end mill holders for your odd sized end mills. Turn a parallel shank on each holder to fit your biggest ER collet, bore a hole the correct size for the end mill shank in the other end, and tap a hole for a grub screw to lock the endmill shank in place. Keep them as short as possible to minimise overhang from the mill spindle. Some of your end mills will probably already have a flat ground on them for this purpose. The threaded or plain shank ones will need a flat ground on the shank for the retaining screw to provide a positive drive.
End mill holders like this are available commercially, but shop made mild steel ones are quite OK for occasional use..
Frank.
11th Oct 2009, 02:24 AM #3Golden Member
- home
- 621
Tiger,
I bought a set of ER25 collets and a MT3 holder for my mini mill from this eBay seller.
At current prices, you'll pay less than $50 for the 15 collects and about $35 for the holder which is a lot less than I payed earlier this year.Geoff
The view from home
11th Oct 2009, 08:24 AM #4
Thanks, Frank and Geoff.
Frank, my largest collet will accomodate 12mm but I like your idea.
Geoff, I've thought about the ER25, do you know how it compares with the ER32?
11th Oct 2009, 02:13 PM #5Golden Member
- home
- 621
Tiger,
The ER25 size was recommended to me as being the biggest I'd need on the X2. The maximum endmill capacity of the X2 is listed as 16mm so anything larger seemed to be a waste.
While the seller I listed does sell ER32 collets, they don't have an MT3 ER32 collet holder.
Edit: Actually the listed eBay seller does have an MT3 ER32 collet holder, it's just not listed on their AU site.Last edited by snowyskiesau; 11th Oct 2009 at 02:19 PM. Reason: New information
Geoff
The view from home
I'm after some odd milling cutters
By funkychicken in forum METALWORK GENERALReplies: 10Last Post: 4th Sep 2009, 09:28 PM -
Tool Holders
By footz in forum THE HERCUS AREAReplies: 9Last Post: 23rd Sep 2008, 10:34 PM
