Results 1 to 9 of 9
30th Sep 2009, 07:20 AM #1New Member
- Apr 2006
- 0
Restoring a bronze motor boat steering wheel
I am looking for advice/assistance in restoring a bronze steering wheel for a boat.
Here is a link to the boaties forum, which expands on the task...
http://www.woodworkforums.com/f32/ad...1/#post1041061
Any advice or assistance appreciated.
Gordon
30th Sep 2009, 12:26 PM #2Most Valued Member
- 4,890
I dont mind having a look at it for you as far as the metal side goes,a lot will depend on how easy it is to remove the RUSTED bolts.
1st Oct 2009, 02:44 PM #3New Member
- Apr 2006
- 0
Dear Pipeclay
The bolts are well and truly corroded so it is unlikely that they can be removed intact.
I thought the best course would be to but them off, drill them out and then re-tap to clean out the residue of the bolt.
Does that make sense?
Also, whereabouts are you in Sydney?
Gordon
1st Oct 2009, 03:12 PM #4Most Valued Member
- 4,890
That method is ok or it maybe possable to Spark Erode them but the cost might be too high.
Im at Erskine Park.
4th Oct 2009, 11:04 AM #5Golden Member
- Apr 2008
- NSW
- 537
Just cut them off , drill them out and retapp to a larger thread diameter .
Then machine up some new bolts from naval brass.The volume of a pizza of thickness 'a' and radius 'z' is given by pi z z a.
5th Oct 2009, 06:05 AM #6New Member
- Apr 2006
- 0
Thank you
With Retromilling's advice in the other thread I ran at http://www.woodworkforums.com/f32/ad...1/#post1041061
I will be able to have ago at it myself.
Thanks all
Gordon
5th Oct 2009, 02:10 PM #7Dave J Guest
Before you try unscewing the bolts, heat the steel bolts to red hot and let cool, this will help break the rusted threads free. Works most of the time for me.
Dave
5th Oct 2009, 03:09 PM #8Golden Member
- Apr 2008
- NSW
- 537
Just be a bit careful with heating it up as steel at cherry red is at approx. 900 C.
Naval brass starts to melt at 888C . Heat is a good loosener for sure but I would not heat it up to any degree of red heat to be on the safe side.
By the time you get to cherry red on a thin bolt the main brass casting could be starting to get too hot.The volume of a pizza of thickness 'a' and radius 'z' is given by pi z z a.
5th Oct 2009, 03:43 PM #9Dave J Guest
If you only use propane you will be right and wont it bother the brass, thats all I use. I don't have the money for oxy/acetylene, it gets expensive with the rental of the mig gases.
Dave
