Results 1 to 11 of 11
2nd Sep 2009, 08:59 PM #1
I'm after some odd milling cutters
I need some tooling that will cut the same profiles as the attached router bits. They're for cutting brass and need to be 1/2"ish diameter
2nd Sep 2009, 09:26 PM #2Dave J Guest
A corner rounding milling cutter and a ball nose end mill is what you are after.The sets on Aus ebay are around $220 for the corner rounding and around $100 for the ball nose end mill set.I am not sure about brass (someone else on here might have experience) or how much you have to do, but I know you can use carbide router bits on aluminium, it might be worth giving it a try on some scrap brass.
Dave
3rd Sep 2009, 01:51 PM #3Member
- Canada
I have done some milling with router bits when in a pinch. If the half round isn't to big and you take light passes you should be able to use a half inch shank router bit to do it, 1/4 inch shank bits aren't rigid enough, for the ball end I would get a proper ballmill cutter they aren't that expensive and quite usefull to have but a router bit should work there to. In the photo I am relieving the flutes on an acme tap I made this was tool steel and it did the job fine.
DarrellLast edited by 12teethperinch; 3rd Sep 2009 at 01:51 PM. Reason: missed a comma
3rd Sep 2009, 08:09 PM #4Member
- Apr 2009
- Marsden, QLD
- 93
First question, what is that material on the cutting face of the router bit made from ?
Second question, how hard is brass ?
Third question, what cuts brass like a hot knife through butter ?
Please answer these 3 simple questions and then if you have the router bit, just bloody well use it.
Problemo solvered.
3rd Sep 2009, 08:27 PM #5
This Mob have what I need, pity there's not in Australia. I'll give Bolts and Industrial supplies a ring tomorrow
4th Sep 2009, 05:37 AM #6Member
- Apr 2009
- Marsden, QLD
- 93
That stuff is FREELY available in Australia, but just not as cheap as that lot.
Better be sitting down when Bolts and Industrial gives you the price for the 1/2 inch ball nosed cutter.
http://www.carbideendmillsplus.com.au/product/6B1204
Have you had a look at what's on E-bay ?
4th Sep 2009, 11:28 AM #7Dave J Guest
I am not sure if you live near a Bunnings store, but they often have cheap sets of router bits $20-$30 or as radish says Ebay.
Dave
4th Sep 2009, 08:42 PM #8Member: Blue and white apron brigade
- 7,183
I have used WW router bits many times on brass but my question to you is what are you going to use to driver the cutters?
4th Sep 2009, 08:50 PM #9Member
- Apr 2009
- Marsden, QLD
- 93
4th Sep 2009, 09:15 PM #10
An HM-52 mill
$18 on ebay seems alright
4th Sep 2009, 09:28 PM #11Member: Blue and white apron brigade
- 7,183
