Results 1 to 9 of 9
25th Jun 2008, 10:40 PM #1
Restore "Todays Posts" button when not logged in...
Could you please replace the "Today's Posts" button on the Main Page when we're not logged in?
- Andy Mc (AKA "Ghost who posts." )
26th Jun 2008, 10:02 AM #2
G'day Skew - We 're limiting access to some parts of the forum for non members and unfortunately the program can't distinguish between guests and members who aren't logged in. There will be some radical changes to what guests see of the forums and how they're viewed by them over the next week or so
However the Todays Post thingy isn't part of this so I'll see what's happened
maybe pulled off inadvertently.
Just a bit of a heads-up. Soon all members will need to either stay logged in or log in to see the regular forum.
Cheers - NeilAre you a registered member? Why not? CLICK HERE TO REGISTER. It's free and takes less than a minute!
26th Jun 2008, 11:55 AM #3
What's prompted the change Neil?
Cheers.
Vernon.
26th Jun 2008, 01:15 PM #4
Also, Why has the split between renovate and this forum caused new posts to only be valid for that particular forum, unlike it used to be previously when it was combined.
this limits the amount of people who will look at posts between the forums
also, had problems logging in when the forum was setup. Is the user/pass the same between the two? Can you not session cookie between them for a common login?
26th Jun 2008, 04:50 PM #5You've got to risk it to get the biscuit
- Jan 2006
- Canberra
- 32
- 593
Neil,
Are the forum skins coming back? ATM there is only three choices and my fave isnt there. no big deal though if it doesnt come back.
cheersS T I R L O
26th Jun 2008, 05:38 PM #6
26th Jun 2008, 06:34 PM #7
Thanks Neil.
Aye. I used to spend quite a bit of time in the reno areas as they pertain(ed) to my work interests but now that they're in an other, seperate forum, well... lately I've barely enough time to scan just this forum!
26th Jun 2008, 09:11 PM #8
I hope the radical changes won't be TOO radical. I wouldn't have discovered this excellent BB without Google's help and some preliminary lurking. In fact, here and one other are the only places I now visit regularly for the latest and greatest of woodturning and woodworking.
And, speaking of "regularly," what, pray tell, is the "regular" forum? The whole WWF? or just the main tab?
Neil, your current signature line says
"Making it better....... I hope
or at least I'm trying to."
You certainly are, in both lines. Thanks again.
JoeOf course truth is stranger than fiction.
Fiction has to make sense. - Mark Twain
28th Jun 2008, 01:14 AM #9Why has the split between renovate and this forum caused new posts to only be valid for that particular forum, unlike it used to be previously when it was combined.
Maybe it is just my perception, but I suspect the posting rate in both forums has drop significantly since the split. I suppose it is still early days, and the posting rate may pick up, but at the moment the renovation forum is an eerie quiet place.
"New Posts" search filter
By dazzler in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 24Last Post: 21st Jan 2008, 10:21 PM -
When clicking "New Posts"
By DJ’s Timber in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 21Last Post: 31st Aug 2007, 07:39 PM -
Big New "edit" button
By watson in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 7Last Post: 9th Jan 2007, 07:16 AM
