Results 1 to 15 of 19
Thread: No New Posts
1st Mar 2008, 06:56 PM #1
No New Posts
Every time I log into the forum and click on the "new post" button I get the the following message
Sorry, there are no new threads to view.
You may search for threads updated during the previous 24 hours, here.
But when I go into the Last 24 hour post there are lots of new ones???Electricity:
One Flash and you're ASH
1st Mar 2008, 07:04 PM #2
Your post is receiving attention!
Is that there under new posts?woody U.K.
"Common looking people are the best in the world: that is the reason the Lord makes so many of them." ~ Abraham Lincoln
1st Mar 2008, 07:18 PM #3
G'day Nev,
Can you give us some details to work on??
How long has the problem existed?
Have you done any "cookie clearing" lately??
What browser are you using??
Can't think of any other questions??
1st Mar 2008, 07:50 PM #4
Interesting thing is it doesn't happen every time
I'm using IE6
And I deleted all the cookies thinking that this was the problem but it didn't fix itElectricity:
1st Mar 2008, 07:51 PM #5
Does the same thing happen (sometimes) on email notifications?
woody U.K.
1st Mar 2008, 09:17 PM #6
Nope it only happens on this forum and http://www.austech.info/ forum
I assume both sites are running the same forum software???Electricity:
1st Mar 2008, 09:36 PM #7Retired
- May 1999
- Tooradin,Victoria,Australia
- 73
- 5,457
You may not be leaving the forums long enough to refresh the page.
The forums have been set to refresh the database every 2 hours I think. If you are on at 8.00 AM and leave at 9.30 AM but return at 9.45AM the time at the top right hand corner will say that you last visited at 8.00 AM and does not record any new posts in that time because it thinks you are still here.
If however you don't return until 3.00PM the new posts should show up.
Hope that makes sense.
1st Mar 2008, 10:35 PM #8
More going on than that, I think. When I hit "New Posts" the software reports "Search results" and it's pretty much up to the minute. If I post a reply, then hit "New Posts," my post is near the top of the list, or below any that were posted in the interim. [** ]
Conversely, if I hit "Today's Posts" before logging in, the list often is headed with something like "The following posts have not been updated since your last visit" even though there really are new posts after I'd logged out. When I last logged out, the message "All cookies cleared" appeared, but I suspect it isn't completely true, and manually clearing the cache as Noel suggests might not be a bad idea.
This software (VBulletin) has enough versions/options/variables to challenge a PhD in computer science. I think there's a forum for VBulletin itself. Some of these weird questions might be addressed there.
[** Like just now.]
JoeLast edited by joe greiner; 1st Mar 2008 at 10:38 PM. Reason: [** added]
Of course truth is stranger than fiction.
Fiction has to make sense. - Mark Twain
2nd Mar 2008, 10:27 AM #9
2nd Mar 2008, 12:01 PM #10
Hi Nev - This is a fix from a long time ago, but try it and it might do the job. Nothing to lose.
Cheers - NeilAre you a registered member? Why not? CLICK HERE TO REGISTER. It's free and takes less than a minute!
2nd Mar 2008, 12:20 PM #11
2nd Mar 2008, 12:28 PM #12
Nev glad your brought it up thought it was just me and my system with New Posts.
Looking forward to see what the mods come up with
I can go on in the am sign out or leave it going and do a New Posts and get the same result as yourself Zilch go back 24hrs.
Good to see you posting again Neil
2nd Mar 2008, 12:39 PM #13
Pending there has been new posts since you last log in
It is more than likely your session cookie isn't receiving its updated visit time.
This can be that
a: you have your browser security too high
b: your firewall is too high and the WW server cant see it or update the session time in the cookie
c: your session cookie is being persistent and not updating
Turn off your firewall
Hit default in browser security
Turn on allow cookies to be set especially if it particular to your firewall to
Allow: http://www.woodworkforums.com
Do a test to see if it updates?
and another if there is a domain shift to "new posts" which redirects to the sub domain I think it was woodworkforums.ubeaut.com ?
Last 24 hours post doesn't use the session cookie. It pulls the time variable from the forum MySql databasec2=a2+b2;
When buildings made with lime are subjected to small movements thay are more likely to develop many fine cracks than the individual large cracks which occur in stiffer cement-bound buildings. Water penetration can dissolve the 'free' lime and transport it. As the water evaporates, this lime is deposited and begins to heal the cracks. This process is called autogenous healing.
2nd Mar 2008, 12:42 PM #14
2nd Mar 2008, 12:43 PM #15
Tick "Remember Me" when you log in. Connects sub-domains.
JoeOf course truth is stranger than fiction.
