Results 1 to 5 of 5
    Adelaide
    68
    1,374
    Default PM screen - not quite right.
    It appears all is not well with the PM code in the forum.
    After clicking on the button to send or reply to a PM the screen stays blank rather than displaying the "message sent" page.
    If you refresh the screen it warns that the form will be resubmitted and then shows the page that warns that the same message cannot new sent within 60 seconds.
    The original sent message is in the "sent" folder so presumably has been issued.
    And the same thing happens when adding a post.
    Adelaide
    68
    1,374
    Quote Originally Posted by Gavin Newman View Post
    But not when replying to a post it would appear.
    If it helps the techs, a Wireshark trace shows the server issuing a 500 error and then the server end drops the TCP connection.
    Frame 19: 306 bytes on wire (2448 bits), 306 bytes captured (2448 bits) on interface 0
    Ethernet II, Src: AvmAudio_3f:a0:ad (5c:49:79:3f:a0:ad), Dst: XX:XX:XX:XX:XX:XX (XX:XX:XX:XX:XX:XX)
    Internet Protocol Version 4, Src: 209.95.48.51, Dst: 192.168.178.48
    Transmission Control Protocol, Src Port: 80, Dst Port: 51554, Seq: 827, Ack: 4612, Len: 240
    Hypertext Transfer Protocol
    HTTP/1.1 500 Internal Server Error\r\n
    Cache-Control: private\r\n
    Pragma: private\r\n
    Content-Type: text/html; charset=ISO-8859-1\r\n
    Content-Length: 0\r\n
    Date: Sat, 23 Feb 2019 18:41:52 GMT\r\n
    Accept-Ranges: bytes\r\n
    Server: LiteSpeed\r\n
    Connection: close\r\n
    \r\n
    [HTTP response 2/2]
    [Time since request: 0.796803000 seconds]
    [Prev request in frame: 5]
    [Prev response in frame: 8]
    [Request in frame: 12]
    Jul 2006
    Athelstone, SA 5076
    4,258
    hey look Gavin...it was half past four in the morning, any real reason you need to wake us up...hahaha
    steven's Avatar
    steven is offline
    Senior Administrator
    The puter Guru
    Feb 2003
    Geelong
    47
    992
    Thanks Gavin, this shouldn't be happening anymore. For a couple of days we ran the site on PHP 7, however some outdated plugins caused the white screen issue. We've got hold of updates and will apply them once i've sorted a couple of other things.
    rgds
    steve
    Woodwork Forums
    Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds!
    Adelaide
    68
    1,374
    Quote Originally Posted by steven View Post
    rgds
    steve
    Yep, PHP7 has broken some features that have been deprecated since 5.x (and earlier) - there's a lot of old code out there that will find life interesting under 7.0. Good luck.
  1. Does this come up on Your Screen.
    By issatree in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 31st Aug 2012, 12:53 PM
  2. Full screen/Part screen
    By Big Shed in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 16th Jan 2007, 12:28 AM
  3. Your Screen Name
    By craigb in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 29th Jun 2005, 10:35 PM
