Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    May 2011
    Murray Bridge S Aust.
    5,942
    Default Problems getting on here??
    Anyone else having problems with getting on here. Have had a few days where I get a message saying that "The server is busy and to try again later"??
    Some times it takes about 3-4 hours, to get on.
    7,182
    Yes - last night from about 8pm till late in them morning.
    Same on WWF - server maintenance?
    May 2011
    5,942
    OK, thanks Bob. Was it an unscheduled one, as I don't recall seeing any notification?
    Nov 2008
    North Brisbane. Qld. Australia
    70
    1,511
    Been getting the same message here. Just visit other forums and try again later. Been happening for about a week.
    Nev.
    Jan 2011
    Far West Wimmera
    63
    4,049
    Me too.
    Sep 2011
    Ballarat
    65
    3,103
    This used to happen at 6.00 every morning a while back but not for quite some time now
    Phil
    Jan 2004
    Mackay North Qld
    6,446
    Ditto,
    Come on you guys!
    There are people working on their weekend to keep this forum up to scratch. Remember it costs you nothing and those fixing the problems don't get paid.
    Obviously theres a bit more than the photo issue going on, so bear with them, OK!
    Jan 2011
    Far West Wimmera
    63
    4,049
    Ditto,
    Come on you guys!
    In my case this is not a recent issue. I have been having problems at least since the forum move and the connection reset issue has been around for a couple of years. This is a problem as I have lost a few long posts.
    I am not pushing however, and if you read the posts nobody else appears to be either. To me they read like they are just confirming that they are not the only ones having issues, so bear with them, OK!
    Sep 2011
    Ballarat
    65
    3,103
    Ditto,
    Come on you guys!
    Ouch. I wasn't having a go at them Grahame I was just saying that the problem had been fixed once before.
    Perhaps it was a poor choice of words on my behalf.
    Phil
    May 1999
    Grovedale (Geelong) Victoria
    74
    6,487
    Hi Folks sorry it has taken so long to get back to this one. Been a bit hectic and also trying to replicate the problem.
    Hectic has finished for a a few minutes.
    So.... Still can't replicate the problem but here's a couple of things to look at.
    • Firstly the 6:00am thing was a back up running and was only ever for less than a couple of minutes maximum.
    • There is another backup at 02:12:32AM until 02:17:32AM that usually takes us off the air for exactly 5 minutes according to the incident report but it's more likely to be for just a few seconds as the check is only run every 5 minutes.
    • Going back through our records there has been one major outage (Network error 06/05/2016 05:12:40PM called from Milan, Italy) which lasted for 5 hours
    • Uptime for last 30 days 99.65% and the 30 days prior to the 5hr network error 98.65%
    Please make sure you are not using www.metalworkforums.com as the forum address. It will work but sometimes caused login problems the correct url is metalworkforums.com note there is no www in that address. Many members had the www bit saved and we did ask for everyone to uss it without www when we went live over here.
    It may be that people experiencing problems are using the old www bit in the web address.
    Is anyone still having a problem with this. If so can you report it here along with the time you got a "Time out" or "The server is busy try again later" message and if and when you were able to get back on again.
    Any problems will be server problems and not forum problems and we have no control over the servers. We do get reports of server outages etc almost the instance they happen and there is a protocol in place to get them notified and back on line asap but if there is no one around at our end then it could take quite some time to fix it.
    Cheers - Neil
    Jan 2011
    Far West Wimmera
    63
    4,049
    Thanks for the follow up and the information Neil.
    I have checked all my shortcuts, but they are correct.
    I suspect some of my issues are related to having a slow satellite connection, which may see a lot of timer related errors on servers.
    I hope these problems will be largely fixed next week as I am hoping my NBN Satellite service will be connected. I have had major problems with organising this as nobody seems to know what is going on. This NBN satellite thingy is brand new after all. My setup is non-standard. There has to be a direct line from the dish to the satellite without interference. The existing dish peeps thru the foliage of a massive gum tree. There is nowhere on the house where this is possible. The office people seem to be totally incapable of passing this information on to the installer. I expressly asked them to pass the information on and still they managed to fail.
    The end result is that I have to provide a trench for the installer to lay conduit/cable from the ground position next to a paddock fence back to the house. I still have not been told exactly how deep this trench needs to be. I am going 450mm. The installer thought either 300mm or 450mm. The trench will be done Tuesday and the installer comes on Thursday.
    May 1999
    74
    6,487
    Good luck with the installation Dean, hope it fixes all your problems for you and doesn't add any new ones.
    Cheers - Neil
    ​Anyone else still having problems logging on???
    Jan 2011
    Far West Wimmera
    63
    4,049
    Quote Originally Posted by ubeaut View Post
    Cheers - Neil
    Next part of the saga occurred this morning. SIGH
    I will post in the proper thread. //metalworkforums.com/f306/t199...rnet-gone-live
    May 1999
    74
    6,487
    Can you let me know what time it was when you had a problem getting on and how long for.
    We are putting on a more sophisticated monitoring program later today or tonight which will tell us a bit more info and maybe pin down exact times when there are any spikes in activity which could cause this problem.
    Anyone else still having problems??
  15. #15
    May 1999
    74
    6,487
    Just checking in.....
    Is anyone still having problems?
    Are you a registered member? Why not? CLICK HERE TO REGISTER. It's free and takes less than a minute!
  1. More VFD problems.
    By mcostello in forum METALWORK GENERAL
    Last Post: 30th May 2015, 06:18 PM
  2. Log in problems
    By wheelinround in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 3rd Mar 2013, 12:40 PM
  3. SAJ VSD problems
    By Ironwood in forum METALWORK GENERAL
    Last Post: 14th Sep 2011, 07:49 PM
  4. BBQ Problems
    By tergar37 in forum METALWORK GENERAL
    Last Post: 17th Sep 2010, 10:09 PM
  5. IE problems
    By Big Shed in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 7th Nov 2006, 09:53 PM
