Results 1 to 9 of 9
19th Jul 2014, 01:34 PM #1Pink 10EE owner
- 6,218
Uploading picture only basic uploader works
I have a problem, it is most likely a browser problem...
When uploading pictures is done in the usual manner, I click upload and just get a red error circle in the box..
Basic uploader works fine..
Any ideas where to look to fix the problem?
Using firefox browser..Gold, the colour of choice for the discerning person.
20th Jul 2014, 04:53 PM #2Steve
Woodwork Forums
Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds!
20th Jul 2014, 06:42 PM #3Pink 10EE owner
- 6,218
This is the problem, if i put the cursor on the red circle the error message come up as shown in the picture. The error message is [ioerrorevent type="ioerror" bubbles=false cancelable=false eventphase=2 text="error#2038"]
Untitled.jpgGold, the colour of choice for the discerning person.
21st Jul 2014, 11:28 PM #4Steve
Woodwork Forums
22nd Jul 2014, 11:36 AM #5Pink 10EE owner
- 6,218
I tried again and still no upload other then using the basic uploader...
29th Jul 2014, 08:15 AM #6
Just letting you know i'm still looking out for a solution to this. I'm leaning toward it being something at your end purely because we'd be overrun with complaints if uploading broke
In the meantime, can you try a couple of things;
- Make sure your firefox installation is up to date
- Test a different browser on the same computer
- In firefox, disable all plugins and if you can upload an image, re-enable them one at a time and maybe you'll identify the problem plugin.
regards
StevenSteve
Woodwork Forums
17th Sep 2014, 09:41 PM #7Pink 10EE owner
- 6,218
Turns out it is my firewall causing the problem..
Eset Smart Security..
If I disable the firewall everything works..Gold, the colour of choice for the discerning person.
17th Sep 2014, 09:57 PM #8Steve
Woodwork Forums
18th Sep 2014, 10:01 AM #9Pink 10EE owner
- 6,218
I run Eset Smart Security, it is an integral firewall and antivirus...... I run manual filtering so when a program requests access to the internet up pops a prompt unless the firewall has a specific rule made up..
Apparently I had denied Flash from incoming connections while allowing outgoing connections... Apparently uploading photo's using the advanced uploader required flash to have access to incoming connections.. While the basic uploader does not..Gold, the colour of choice for the discerning person.
Errors while uploading .jpg attachments and I need help!!
By Burner in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 3Last Post: 16th Sep 2013, 05:59 PM -
FIXED Photos not uploading
By Hermit in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 18Last Post: 28th May 2013, 10:33 PM -
Uploading jpg images
By Alby123 in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 1Last Post: 27th May 2013, 06:41 PM -
Uploading photos
By BUNDYMARK in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 2Last Post: 8th Mar 2011, 07:23 PM
