Results 1 to 9 of 9
    Mar 2013
    Edinburgh
    4
    Default Bearing/fulcrum o use for a pendulum
    I want to swing a locket on a chain like a pendulum and I want to minmise the friction experienced where the chain attaches to the supporting post. What sort of bearing or similar device should I use for this? Ideally it should be available in a bronze/dirty brass colour but I guess I can deal with it if it isn't.
    Feb 2015
    Oz
    73
    459
    Knife edge.
    Aug 2011
    4,779
    What he said.
    Many years ago in a previous life I work on a gas densitometer. It consisted of a sealed vessel with a float inside. The float was connected to a pendulum with a needle against a graduated scale with the zero position in the middle. It worked by connecting the vessel to a vacuum pump and evacuating the air to close to zero absolute and then introducing the gas to be measured. You would then manually swing the pendulum while introducing the gas and when the "average" position of the needle was zero (time in the +ve equalled the time in the -ve) then you would make calculations and determine the density of the gas from known variables such as the pressure etc..
    My project involved automating that machine by using a sensor to measure the time the needle spent above and below the zero position and then return a digital reading. Anyway, needless to say that this pendulum needed to has the least amount of friction as possible, not that friction introduced any errors as it was equal in both the -ve and +ve regions but the less friction the better. Its design concorporated a lovely knife edge for this reason.
    Mar 2013
    Edinburgh
    4
    Thanks. Is that something I can buy? I can't find anything on eBay. I also forgot to include the word 'cheap' in my first post!
    Aug 2011
    4,779
    Hi,
    Not sure. My first thought was that you would make it. It couldn't be too difficult.
    Jan 2004
    Mackay North Qld
    6,446
    THX1138
    Welcome to the Metalwork Forum.
    Since we have a jewelry sub forum I'll move this thread
    Feb 2015
    Oz
    73
    459
    Doesn't get much cheaper than a file.
    Dec 2005
    South Australia
    1,658
    I may be missing something here, just use a bail or jump ring
    Oct 2015
    melbourne
    473
    Just to confirm :
    The pendulum consists of a locket and chain. You want a suspension of that is low cost, but presumably low friction to get maximum 'run time'. Do you need to constrain the direction, ie keep it in a straight line?
    I'd reckon a knife edge as above would be best, but next a suspension spring may be easier. Lots for sale, they are used in clocks.
    Or make one from a short strip of springy brass, for example. Or even 2 parallel threads.
    I think a single jump ring wouldn't control it but is definitely the easiest.
    -russ
  1. Measure twist with a pendulum ?
    Last Post: 9th Feb 2015, 05:54 AM
  2. Bearing
    By WesP in forum METALWORK GENERAL
    Last Post: 25th Oct 2014, 12:16 PM
  3. Completed (almost) Pendulum Level
    By tongleh in forum METALWORK GENERAL
    Last Post: 3rd Sep 2012, 02:39 PM
  4. Pendulum Level
    Last Post: 31st Aug 2012, 09:42 PM
