Results 1 to 8 of 8
10th Jun 2019, 09:12 PM #1Senior Member
- Dec 2011
- Rosebery/Eastlakes
- 115
Damaged motor reversing drum switch
Hi All,
The motor reversing switch for the New Visby lathe I have has two issues:
1. There is a LOT of play in the switching contactor mechanism meaning sometimes the detents won't engage relative to each of the 3 switching positions (forward, neutral and reverse), and;
2. the bakelite insulator has been cracked from a blow to the side of the metal enclosure.
I guess my question is: does a similar style switch still exist today as a direct replacement or do I need to somehow retrofit a modern drum switch into this enclosure?
Any advice would be appreciated.
Flo
10th Jun 2019, 11:50 PM #2China
- Dec 2005
- South Australia
- 1,657
My honest opinion chuck it out and buy a new one
11th Jun 2019, 12:55 AM #3Senior Member
- Dec 2011
- 115
11th Jun 2019, 07:49 AM #4
Hi Flo,
I agree, replace it with a modern one ! Rotary switches are quite common though may be a little pricey. just make sure that it is AC rated for the load that you are using.
You may have to buy a suitable box to house it as well.Best Regards:
14th Jun 2019, 11:10 AM #5Golden Member
- Dec 2007
- 574
Reversing drum switches are available but it is highly unlikely they will be a direct physical replacement the attached pic is from Aliexpress.
14th Jun 2019, 11:59 AM #6Member: Blue and white apron brigade
Some interesting electrical specs????
14th Jun 2019, 07:59 PM #7
By gum that seems very cheap ! You couldn't get one for that price here in the UK.Best Regards:
14th Jun 2019, 09:58 PM #8Senior Member
- Dec 2011
- 115
Thanks for that.. I have seen these switches and I'm suspecting that what you're saying about direct replacements is going to be the case.
Interestingly I have had a closer look at the existing switch and a lot of the excess play was attributable to a loose lever grub screw. The cracked bakelite piece was only a cover and so I used some JB Weld and repaired it and panel-beated the switch enclosure to relieve any residual pressure on the cover. So we'll see how it goes..
Reversing switch Hercus lathe?
By neksmerj in forum METALWORK GENERALReplies: 41Last Post: 31st Dec 2022, 11:21 PM -
Is a motor start relay switch needed for a 3ph 2.8kw pump motor?
By Ben Dono in forum METALWORK GENERALReplies: 26Last Post: 14th Aug 2015, 02:38 PM -
Reversing Switch
By wheelinround in forum METALWORK GENERALReplies: 0Last Post: 22nd Feb 2015, 03:34 PM -
Single phase and adding a reversing switch
By NoobHercusOwner in forum THE HERCUS AREAReplies: 10Last Post: 26th Sep 2014, 11:58 AM -
Reversing drum switch on ebay.
By mob in forum THE HERCUS AREAReplies: 12Last Post: 18th Jan 2010, 12:32 AM
