Results 1 to 2 of 2
    Apr 2018
    Sydney
    64
    Default Help Identify and wire motor
    Hi,
    I have this large what looks to be a DC motor (BLDC?)
    It is bolted inside a machine at the moment so these are the best pictures I can get.
    I managed to use a mirror to take a picture of the ID plate for the motor.
    In the junction box there are wires labeled T1, T2, A1, C1, E1, E2.
    T1/T2 and A1/C1 have continuity while E1 and E2 does not have continuity and also does not have ground leakage.
    Can anyone help identify the type of motor and how to test it?
    near Rockhampton
    6,216
    If F means the field voltage at 200V and A means armature voltage of 160V then like a 10EE lathe it will need a complicated controller.
    I take it it is off something with variable speed and lots of torque down low.
  1. Delta wire bridgeport motor
    By StrayAlien in forum ELECTRICALS
    Last Post: 26th Mar 2018, 08:20 AM
  2. Can I wire this 3ph motor to VFD?
    By GDD in forum METALWORK GENERAL
    Last Post: 2nd Nov 2015, 06:44 AM
  3. Replies: 26
    Last Post: 14th Aug 2015, 02:38 PM
  4. Replies: 16
    Last Post: 24th Nov 2012, 09:47 PM
