Results 16 to 30 of 31
  1. #16
    Oct 2004
    Glen Forrest, Western Australia
    62
    80
    Is this how you wired it ?
    Rick
  2. #17
    Charlestown NSW
    65
    1,669
    Rick
    yes thats it
    peter
  3. #18
    Aug 2006
    1,105
    I have the same Tacho and mine is wired the same way. Led on the sensor is on and the Tacho display reads 0000 without machine running. Not sure what is going on with yours. It is unusual with two giving you the same result.
    I am powering mine with a 9V plug pack from an old cordless phone. Have you checked what voltage yours is putting out with a multimeter?
  4. #19
    Aug 2006
    1,105
    I just disconnected the sensor and it still will read 0000, does yours do the same or will it still display 5997 RPM?
  5. #20
    Charlestown NSW
    65
    1,669
    Quote Originally Posted by Com_VC View Post
    My power supply is putting out 14V. I think I have a couple of 12v plug packs which I'll dig out tomorrow although as the Tacho is supposed to run on 8-24V I cant see how that would be a factor. However desperate men etc.
    When I disconnect the sensor the readout displays 0000
    I've just gone and checked both, they are almost exactly the same. I have also swapped the sensors with no difference.
    I wish I could get the same sort of odds buying a lottery ticket.
  6. #21
    Aug 2006
    1,105
  7. #22
    Oct 2004
    62
    80
    Quote Originally Posted by bollie7 View Post
    The red LED at the back of the sensor lights up but the readout immediately goes to around 5997 RPM.
    Is the light and get brighter when the magnet gets closer ?
    Do you have a photo of your wiring just in case you missed something, not that I doubt you but stranger things have happened
    Rick
  8. #23
    Charlestown NSW
    65
    1,669
    The number on both the sensors is SJA12-10N1
  9. #24
    Charlestown NSW
    65
    1,669
    Quote Originally Posted by warrick View Post
    Not that I have noticed
    Rick[/QUOTE] Better than that. This link is to the short video I made of the first tacho to send to Banggood.
    https://youtu.be/X1iziOhrMK4
    I think i have the wiring correct but I'm certainly open to be corrected if I havent.
  10. #25
    Oct 2004
    62
    80
    Peter,
    If you have the wiring correct then there should be the LED on and it gets brighter when the magnet is in close proximity, I also think that it is pole sensitive (i.e. it likes one side of the magnet to the other)
    It is very hard to see the wiring as it is twisted and the camera is moving so a photo would be better, also a photo of the sensor showing the diagram on it
    Rick
  11. #26
    Charlestown NSW
    65
    1,669
    Rick.
    The orientation of the magnet doesnt change anything. I have just tried it from both sides.
    Yes the LED does get brighter when the sensor is closer to the magnet. Changes approx 6 or 7 mm from the magnet.
    Whe the sensor is not close to the magnet the readout shows this.
    Closer than 6 or 7 mm the LED is brighter and the read out shows this
    Wiring pic
    sensor
    label
    thanks
    Peter
  12. #27
    Oct 2015
    melbourne
    473
    I'd try a different power supply. Yours may not be filtered well enough. Even a battery - say cordless drill battery.
    Russ
  13. #28
    Oct 2004
    62
    80
    Quote Originally Posted by russ57 View Post
    Russ
    If I remember correctly I had problems when I first tried hooking one up and realised I had a AC powerpack so using another source would be a good suggestion.
    I went out to my shed and checked the wiring on mine and it is exactly the same as yours Peter so the power supply look to be the only thing to change now
    Rick
  14. #29
    7,183
    My power supply is putting out 14V. I think I have a couple of 12v plug packs which I'll dig out tomorrow although as the Tacho is supposed to run on 8-24V I cant see how that would be a factor. However desperate men etc..
    My experience is that just using a multimeter to measure the output of a PS often misses most of the story. Some are super noisy and/or show a fair bit of residual AC - try measuring its AC output.
  15. #30
    Charlestown NSW
    65
    1,669
    so the power supply look to be the only thing to change now Rick
    I tried a 9V plug pack supply just now and the results look very encouraging. Learn something new everyday. It gives a read out that is very close to what I'm getting from the hand held optical one I have here. Next step is to see if it works with the 12V supply I have on the mill for running the lights and the fans in the VFD enclosure.
    Thanks so much to all who have offered suggestions. I really appreciate the help.
    Peter
  1. Replies: 27
    Last Post: 15th Oct 2014, 08:34 AM
  2. High Speed Spindle for the Mill
    Last Post: 11th Sep 2012, 02:44 AM
  3. Mini lathe/mill project No.1 Saw arbor
    Last Post: 20th May 2012, 11:38 AM
  4. Dial Indicator Set up for Hercus Mill
    By Abratool in forum METALWORK GENERAL
    Last Post: 16th May 2012, 09:39 PM
  5. Mini lathe/mill project No.2 Fly cutter
    Last Post: 9th Mar 2009, 01:11 PM
