Results 1 to 15 of 31
19th Apr 2019, 11:15 AM #1Diamond Member
- Sydney, NSW
- 1,249
Future Project - Speed Indicator for MIll
Hi Blokes,
I want to attache a speed indicator to my mill. But I have little experience with electrical work so I'm asking what I need and how to go about it.
I'd probably get my materials for Jay Car.
If anyone has done it and has a build log or knows of a U tube series that would be really helpful.
Regards Ben.
19th Apr 2019, 12:17 PM #2Diamond Member
- Aug 2006
- 1,105
Something like this is probably what you are after I think. You can set it up to run from a plug pack type power supply.
https://www.ebay.com.au/itm/4-Digita...4AAOSwXaxasfBe
19th Apr 2019, 08:15 PM #3Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 831
The unit shown by ComVC would be a good choice. I set up something similar on my milling machine as shown in this thread starting at post #134:
//metalworkforums.com/f65/t1592...illing+machine
20th Apr 2019, 12:13 AM #4
20th Apr 2019, 07:53 AM #5Most Valued Member
Same, I have used similar setups on two machines although I sourced the components individually on ebay rather than as a kit.
They work very well and cheap as chips. I did however have an issue initially with the one mounted on my mill. It picked up noise from the VFD and gave erratic readings. It was a simple fix of using a 0.1uF MKT capacitor as a basic low pass filter by connecting it across the signal in and ground.
20th Apr 2019, 11:16 AM #6Philomath in training
- 6,538
You can't just use an optical tacho from ebay? Cheap, self contained and no working out why the electrons won't behave.
20th Apr 2019, 11:22 AM #7Diamond Member
- Aug 2006
- 1,105
One of these? https://www.ebay.com.au/itm/Mini-Pro...frcectupt=true
I have one of those, but fixed permanent display is a much better option.
20th Apr 2019, 12:20 PM #8Diamond Member
- Sydney, NSW
- 1,249
20th Apr 2019, 02:12 PM #9Member: Blue and white apron brigade
- 7,177
20th Apr 2019, 05:20 PM #10Golden Member
- Sep 2008
- 831
20th Apr 2019, 08:37 PM #11
I have one of these, they do work very well. They come with some self adhesive reflector strips which you apply to to item you want to measure the speed of.
However I did find that mine also picked up electrical noise from the motor brushes arcing as the motor turned. easily recognised by the erratic readings. Moving further away from the source of the interference solved the problem.Best Regards:
20th Apr 2019, 11:26 PM #12Most Valued Member
- Charlestown NSW
- 1,669
I recently bought one of this type from Banggood. I think it was about $12.00. When it arrived I tried to get it working but it constantly showed 5990 RPM. Even the electronics techos at work couldn't get it working. So I contacted Banggood and told them the story. No problems, they are sending me another one. Hopefully it will work a bit better than the first one.
For some reason I didn't even look on ebay at the time.
If I had I would have paid the extra $4 to get one that was already here in Aus.
peter
21st Apr 2019, 09:12 AM #13Philomath in training
- 6,538
I guess the relevant question is whether your mill has a fixed speed gear box (or belts) and you just want to check the speed occasionally, or whether it is variable speed and needs near constant checking.
21st Apr 2019, 09:27 AM #14Member: Blue and white apron brigade
- 7,177
I have an optical tacho purchased more than 12 years ago - I've used it a lot on motor HP measurements where it stays on for 1/2hr periods or so at a time - its still running from the same battery it came with. The optical ones can suffer from false readings if a second or high reflectivity patch is picked up. This can be checked by placing a second reflective patch on the rotating object and the readout should double - if not you have a reflective patches involved. Running or painting a dark non reflective stripe around shafts etc and placing the reflective patch on the dark stripe is a way around it.
I'm also after something a little more permanent. Will give one of those inductive ones a go.
3rd May 2019, 03:46 PM #15Most Valued Member
- Charlestown NSW
- 1,669
Well my replacement Tacho arrived from Banggood recently. Just got to try it out. Wired it up how I believe to be the correct way and got exactly the same result as the first one.
So that means I'm either wiring it up incorrectly or by some massive fluke I have been sent two faulty ones.
So can someone tell me the correct way to wire these please? The directions are, typically for China origin stuff, not very clear.
This pic is what I got directly from the Banggood listing.
This one is the new one (replacement) I have on the bench
So I have 12V + going to terminal no 1
12V- _ to terminal no 2
Sensor Brown going to term no 1
Blue going to term no 3
Black going to term no 5
Terminal 4 is not used
The red LED at the back of the sensor lights up but the readout immediately goes to around 5997 RPM.
With the magnet attached to my drill chuck and the drill running the readout fluctuates all over the place.
Any help would be greatly appreciated.
thanks
Peter
Variable Lathe spindle speed control project for constant surface speed
By jhovel in forum METALWORK GENERALReplies: 27Last Post: 15th Oct 2014, 08:34 AM -
High Speed Spindle for the Mill
By RayG in forum METALWORK GENERALReplies: 10Last Post: 11th Sep 2012, 02:44 AM -
Mini lathe/mill project No.1 Saw arbor
By neksmerj in forum METALWORK GENERALReplies: 11Last Post: 20th May 2012, 11:38 AM -
Dial Indicator Set up for Hercus Mill
By Abratool in forum METALWORK GENERALReplies: 11Last Post: 16th May 2012, 09:39 PM -
Mini lathe/mill project No.2 Fly cutter
By neksmerj in forum METALWORK GENERALReplies: 1Last Post: 9th Mar 2009, 01:11 PM
