Results 1 to 7 of 7
10th Feb 2019, 05:38 PM #1Intermediate Member
- Sep 2016
- Morphett Vale SA
- 56
- 27
Mossner Rekord bandsaw,which VFD?
Hi all,as the title says,a large piece of German machinery followed me home this week in the form of a 1970 Mossner Rekord SSF420 vertical bandsaw,3 phase of course.
2_resized.jpg.I've removed the motor and upon inspection of the electric motor plate I at first thought it was 2.2kw 415 volts 5 Amps 3 phase delta only.
1_resized.jpgOn the underside of the connection box cover there was the usual diagram to change the connections to star,does this configuration also change it to low voltage ie 240volts 3phase?
On the other 2 other 3phase machines I have the motor plates list various voltages and amps,So choosing a VFD was relatively easy.
I changed the terminals to star and have temporarily connected it to the VFD I use for my shaper and it runs fine{no load},at the correct rpms at 50Hz as verified with a tacho.My question is if the plate states 415v3ph draws 5amps,is there a formula to calculate how many amps will it pull on 240v 3ph? and therefore which VFD? I have a Huanyang on the shaper and a AC tech on the mill,so maybe its time to give a Powtran a go but what size? and what model.This band saw has a hydraulic/gravity power feed system so I'd like to keep as much of the original horsepower as possible.
Thanks,NickLast edited by rustyovali; 10th Feb 2019 at 06:34 PM. Reason: typo
10th Feb 2019, 07:43 PM #2Philomath in training
From memory, a 3 phase motor should be wired in delta for use on a VFD. Confirmation someone?
10th Feb 2019, 08:00 PM #3Member: Blue and white apron brigade
Not necessarily - it should be wired to fit the voltage that develops its full power.
It just so happens that if a 415V Y wired motor is converted to ∆ it will run on full power on 240v.
If it is 415V ∆ then you are screwed because converting it to Y means it will only develop full power at ~800V.
In both cases it will run BUT if you try and run it under load you will eventually kill the motor - Like I did on a compressor.
The compressor came with a 4HP 415V ∆ that was burnt out so ai replaced it with a $30 5HP 415V ∆ (makes about 2.5HP on 240V 3P) and it lasted for about 6 months.
There is no need to worry about current - just work on power. If it's a 2.2kW motor then that's 2.2kW whether its 240 or 415V.
Then get a VFD that is rated for that power.
For something like that BS I'd for a Powtran PI160 model. See attachment
PI160 2R2G1
Im using the 1.5kW versions on my Lathe and Drill press.
10th Feb 2019, 08:02 PM #4Diamond Member
- Jun 2010
- Canberra
- 1,322
A 415V star motor can be run at 240V delta, but the nameplate shows this to be a 415V delta motor, so it won't perform to spec on 240V, and changing it to star will make it even worse.
[Edit] Beaten by the VFD expert
10th Feb 2019, 08:12 PM #5Intermediate Member
- Sep 2016
- Morphett Vale SA
- 56
- 27
10th Feb 2019, 08:38 PM #6Intermediate Member
- Sep 2016
- Morphett Vale SA
- 56
- 27
Hi BobL,just saw the attachment,thanks.As the motor plate says 415 delta,{see photo in first post} Do you know if a PI 160 2R2G3Z uses single phase input? or is it 3phase in,3 phase out?
10th Feb 2019, 08:52 PM #7Member: Blue and white apron brigade
FS BS-? Bandsaw
By caskwarrior in forum METALWORK - Machinery, Equipment, MARKETReplies: 12Last Post: 4th Dec 2018, 05:59 PM -
bandsaw
By shaper07 in forum METALWORK GENERALReplies: 7Last Post: 23rd Aug 2016, 01:34 AM -
BANDSAW
By pench in forum METALWORK GENERALReplies: 10Last Post: 12th Oct 2014, 06:59 AM -
Cut off saw or Bandsaw
By Jim Ferrous in forum METALWORK GENERALReplies: 29Last Post: 22nd Oct 2013, 06:39 AM -
Bandsaw
By Pete F in forum METALWORK GENERALReplies: 25Last Post: 11th Sep 2009, 05:27 PM
