Results 1 to 15 of 15
Thread: Single phase motor questions
28th Jan 2019, 06:54 PM #1Most Valued Member
- 2,672
Picked up a nice 6" Glen (Glentanner) bench grinder on the weekend, but unfortunately its doesn't run.
Checked the start capacitor, its fine. Centrifugal switch is also OK.
I'm a confused about the windings though.
To start with, this is what I'm assuming is the circuit and winding relationship. The switch is the centrifugal switch:
If I check the resistance across the line connections to the motor, I get an open circuit ( I expected to get low resistance from the run winding if the winding was good)
If I remove the capacitor and check the resistance across the terminals that connect to it - I get low resistance (centrifugal switch closed). Thats what I'd normally expect, but not if the run winding was open circuit.
Its got me a bit baffled so thinking I'm making a wrong assumption somewhere.
28th Jan 2019, 07:05 PM #2Member: Blue and white apron brigade
Sounds like the main winding is OC.
28th Jan 2019, 07:05 PM #3Most Valued Member
- 2,672
This is the inside.
Red terminals go to start cap.
Blue to main on/off switch.
28th Jan 2019, 07:57 PM #4Most Valued Member
- 2,672
28th Jan 2019, 08:15 PM #5Member: Blue and white apron brigade
Earths OK?
28th Jan 2019, 09:06 PM #6Most Valued Member
- 2,672
None of the windings are shorted to earth if that's what you're asking.
Think it's making a bit more sense now.
If I remove the start cap, then AC 0 ohms
AD 38 ohms
AB OC
If I connect CD, then AB is still OC, so seems that it's broken between B and F.
Does that make sense?
28th Jan 2019, 09:59 PM #7Member: Blue and white apron brigade
29th Jan 2019, 08:47 PM #8Most Valued Member
- 2,672
The culprit. Guessing a dry solder joint that get a bit hot. Prized apart slightly for your viewing pleasure
29th Jan 2019, 09:08 PM #9
Hi Steve,
Good work on finding that bad joint ! A quick rub with some sandpaper and solder them back together. Don't forget to put some insulating sleeve on as well.Best Regards:
30th Jan 2019, 09:56 PM #10Most Valued Member
- 2,672
Cleaned it up and soldered back together, with some fiberglass "spaghetti tube" over the joint, and bit of 5 min Araldite to keep everything in place.
Tests out fine electrically, but will grab a couple of new bearings tomorrow before I put it back together. Bearings aren't bad but may as well take the opportunity while it's apart.
Unless anyone knows of a reason behind the single metal shield bearings fitted, it will be getting double rubber sealed ones!
31st Jan 2019, 07:05 AM #11
Hi Steve,
As far as I'm aware only the friction of the rubber seal against the inner surface.
When I put new bearings into the 8" grinder that I refurbished, I only used single metal shielded ones.
I posted pictures quite some time ago.Best Regards:
31st Jan 2019, 03:02 PM #12Most Valued Member
- 2,672
Thanks Baron. The obsessive side of me says that using metal shields in an environment with grinder dust is asking for a reduced bearing life, but obviously in practice its non-issue.
I bought 2 of each types at the bearing shop today. Will see how I feel tonight as to which ones I fit
31st Jan 2019, 08:31 PM #13
Good Morning Steve,
FWIW there is no venting on the grinder that I refurbished, so there isn't any airflow through the motor to drag grinding dust into the bearings. To be honest the only grinders I've seen with vented motors, have been the pedestal type where the motor is in the base of the column, and they get really filthy with particles from belt wear.
So I don't think it will make any difference which ones you fit.Best Regards:
31st Jan 2019, 08:55 PM #14Most Valued Member
- 2,672
Fair comment. Think I'll just fit the metal shielded ones then and save the RS for something more deserving
1st Feb 2019, 07:31 PM #15Most Valued Member
- 2,672
All back together and purring like a kitten
Just have to decide which wheels to put on it.
3 Phase Generator Motor Powered by Single Phase Motor?
By gazza2009au in forum ELECTRICALSReplies: 49Last Post: 4th Apr 2020, 04:38 PM -
Single phase Vs 3 phase motor ratings.
By KBs PensNmore in forum ELECTRICALSReplies: 56Last Post: 17th Sep 2017, 05:37 AM -
Replacing A Single Phase Motor With A Three Phase Motor....................
By matthew_g in forum METALWORK GENERALReplies: 26Last Post: 1st May 2015, 04:42 PM -
rewire 3 phase motor to single phase
By thorens in forum METALWORK GENERALReplies: 36Last Post: 5th Sep 2014, 07:16 PM -
Looking to swap a 2Hp single phase motor for 1.5 or 2Hp 3-phase motor
By jhovel in forum METALWORK GENERALReplies: 7Last Post: 10th Mar 2014, 07:26 PM
