Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    6,443
    Thumbs up Ring Mains Wiring !
    Having read the threads below, the question does pop into my head, Do you use "ring main" wiring systems in AU ?
    Aug 2000
    34
    No not like you do in blighty!
    Also no fuses in our standard 3 pin plugs either.
    Jun 2010
    Canberra
    1,322
    As mentioned, we don't, but I do like to talk about running ring mains and using wire nuts when winding up Australian sparkies on forums who are convinced we're all doing illegal DIY wiring.
    6,443
    Thanks Guys,
    It is interesting learning about the different systems and practices in different parts of the world. I didn't know about the lack of fused plugs for instance.
    As far as wiring nuts is concerned, I thought that they were discontinued years ago !
    NOTE: For some reason I can no longer activate any of the "likes, thanks or pictures" at the moment. Sorry !
    Aug 2010
    ACT
    84
    268
    Hi,
    Yes most Australian sparkies get a shocked look when someone who has worked with such things describe it to them.
    The Australian wiring regs specifically ban ring mains and fuses in plug tops.
    Hugh
    Enough is enough, more than enough is too much.
    Jul 2011
    Adelaide
    837
    No they are specifically banned. Testing their correct operation is a bit more complex. Our licence holders can't keep up with the safety record of NZ DIYers so it would probably be unwise to introduce more complexity into their lives.
    6,443
    I'm somewhat surprised by that ! Ring mains have been the standard here for years now. Even so the regs specify the maximum number of 13 amp outlets you can put on a ring of a particular size core.
    As far as I'm aware the ring main was introduced just after the war, because of the shortage of copper, and as time progressed became single copper cores rather than the multiple strand core of the previous domestic wiring. Higher capacity cables still use multiple strands.
    near Rockhampton
    6,216
    Is the main point of the "ring" method that the electrical force has the opportunity to get to the GPO via two different paths?
    what happens if you get a conductor breakage. Then wouldn't it potentially overload the cable as the electrical force can not longer travel both ways to the GPO?
    Jul 2011
    Adelaide
    837
    It has two main points. One is the higher current capacity for a given size of wire (given any allowances for type of enclosure) because you have two paths for the current. The other is that is the earth also is connected twice so a break in the earth affects less of the circuit.
    6,443
    Quote Originally Posted by lamestllama View Post
    it has two main points. One is the higher current capacity for a given size of wire (given any allowances for type of enclosure) because you have two paths for the current. The other is that is the earth also is connected twice so a break in the earth affects less of the circuit.
    Spot on. Right on both counts.
    Not forgetting the additional protection of fuses in the plug. These have a maximum rating of 13 Amps and whilst there are larger capacity fuses, they are also physically much larger and will not fit into the plug top. These fuses are usually sold in packs of five or ten with ratings from 3 Amps, 5 Amps, 10 Amps and 13 Amps.
    Jul 2011
    Adelaide
    837
    Not to forget the shutters in the socket operated by the longer earth pin that stop people sticking stuff into the live contacts without really really trying.
    Nov 2017
    Geelong, Australia
    57
    2,651
    Thanks Guys,
    <snip>
    Apparently its a bug since the upgrade on 13th - the admin has it on the todo list.
    //metalworkforums.com/f36/t2028...um-update-post
    6,443
    Hi Steve,
    Thank you for that information ! I did think it was a Firefox bug following an update to it on my machine. When I click any of the four items the bottom of the page just blanks and I get a "JavaScript" failure message.
    Jan 2004
    Mackay North Qld
    6,446
    ADDED BY ADMIN
    DISCLAIMER
    No liability is accepted by The Senior Administrator or the Metal Work Forum's moderators
    for advice offered by members posting replies
    or asking questions regarding electrical work.
    We strongly advise contacting a Licensed Tradesperson for all electrical work.
    WARNING
    Information supplied within posts is not to be considered as detailed formal instructions to complete a task.
    Members following such information do so at their own risk
  15. #15
    Apr 2019
    Queensland
    12
    Default Why
    The ring circuit was introduced in to the UK during the war to save copper. Each outlet is fed via two cables of half the size. The cable is protected but an overload device matched to the two cables in parallel. It's not a good system. One issue is a break in one cable can allow an overload in the other. However, this isn't as bad as it sounds when you understand how cable current ratings are calculated ( as every electrician should!).
  1. Ring roller
    By KBs PensNmore in forum WANTED TO BUY
    Last Post: 21st Jun 2018, 12:23 AM
  2. Another ring roller
    Last Post: 15th Apr 2017, 01:12 PM
  3. H&F Ring Roller
    By Dingo Dog in forum METALWORK GENERAL
    Last Post: 13th Apr 2017, 09:26 PM
  4. O-Ring Supplier
    By Normanj in forum METALWORK GENERAL
    Last Post: 30th Nov 2010, 09:36 AM
