Results 1 to 10 of 10
    Oct 2011
    Sydney, NSW
    1,249
    Default Start Up Capacitor - Where to buy?
    Hi,
    I think the start up capacitor on my lathe has died.
    I want to replace it but not sure where to get one from. I've looked at ebay and came up with this:
    https://www.ebay.com/itm/Appliance-M...A/272321181127
    Local seller and its seems to match what I have. I've tried electrical retailers online but I'm struggling to find anything else.
    Any suggestions?
    Jan 2012
    149
    7,189
    The main thing to match is the "Capacitance" in microFarads (MF) it should not be more than ~20% higher or lower that the original
    Voltage wise , equal to or higher is OK.
    Likewise with the max temperature rating (more is OK but not less).
    6,480
    Hi Ben,
    If you are not in a hurry, this looks OK. Wire end rather than amp tags but just use a chocolate block to join the wires.
    https://www.ebay.com/itm/Black-100uF....c100005.m1851
    Jul 2006
    Athelstone, SA 5076
    4,258
    as BobL says make sure you get one at least close to 120mfd...200 is way too big
    as Niel says...Actrol, Heatcraft or Airfrige would most likely have one, but ebay should be cheaper
    Oct 2011
    Sydney, NSW
    1,249
    Hi,
    I bought the ebay one in the OT. It was a lot bigger than the original one but it still fitted in ok. I fired it up today - was very nervous. It worked and I'm still alive! It seems to me that the start up seems less sudden than before. Is this possible?
    Ben
    Oct 2011
    Sydney, NSW
    1,249
    I just read Eskimo and BobL's posts, obviously I'm not an electrician!
    6,480
    Hello Ben,
    The bigger capacitance will have a lower reactance (AC Resistance) than the original. This will increase the start up current through the start winding resulting in the softer start. As long as it gets up to speed quickly, it should be allright, the centrifugal switch will open the circuit, disconnecting the capacitor and start windings from the supply voltage.
    Oct 2011
    Sydney, NSW
    1,249
    Hello Ben,
    Yep, its gets up to speed quickly but it doesn't give that sudden violent shock I used to get when starting up.
    Ben
    Dec 2009
    Sydney
    327
    Might e too late, but Hare & Forbes had big fat 75uF / 250v units for $2 each. Down the back, at the clearance section.
    regs,
    A.
    'Waratah' spring hammer by Hands & Scott c.1911- 20, 'Duffy, Todd & Williams' spring hammer c.1920, Premo lathe- 1953, Premo filing machine.
  1. Burst Capacitor
    By kenny_10 in forum ELECTRICALS
    Last Post: 7th Oct 2018, 02:49 AM
  2. Capacitor types
    Last Post: 29th Jun 2018, 06:06 PM
  3. 3phase on single phase plus a capacitor ?
    Last Post: 8th Feb 2015, 10:25 PM
  4. Need help finding a capacitor for my lathe motor
    By xXvapourXx in forum METALWORK GENERAL
    Last Post: 29th Oct 2013, 10:34 PM
  5. Capacitor for CIG Transtig 180 info required.
    By Old Croc in forum WELDING
    Last Post: 17th Mar 2013, 01:45 AM
