Results 16 to 20 of 20
Thread: Bandsaw motor questions
23rd Oct 2018, 08:47 PM #16
Hi Steve,
That looks like a very nice megger you have bought. If I may ask where did it come from and how much ?
My old megger uses a now obsolete rechargeable Nicad battery, it doesn't get used too much nowadays but I do get annoyed when I want to use it and have to put the battery on charge to get 10 minutes use out of it.Best Regards:
23rd Oct 2018, 09:02 PM #17Most Valued Member
- 2,671
Just a generic Chinese special via eBay. AUD$57 delivered from a local seller.
I checked out a few reviews and seems they are reasonable.
It's got normal voltage and resistance ranges too and I reckon with that huge display (backlit if you want) it's going to get a bit of use in general. Ive got a couple of other multimeters but none have the backlight.
It's only a plastic case so won't take a lot of abuse.
PS. The brand name varies, but they all have the same model number so search on that for info.
23rd Oct 2018, 09:07 PM #18
Thank you for that info ! I didn't realise that it was a multimeter as well, and the price is right.
30th Oct 2018, 10:31 AM #19Most Valued Member
- 2,671
Just to round this up, I gave the motor a quick run for a few seconds on real 3 phase (as opposed to what comes out of my RPC).
Didn't want to run it for any longer as nothing has been cleaned/lubed so didn't want to cause any damage.
Will strip it down when I do the rest of the bandsaw and have a quick look for the star point to see how accessible it is, but at least I now know I the motor is good and should run fine on my RPC at home.
The megger is about to get its second job tonight.
I rescued a scrapped 4kw motor with integral brake the other day. The brake was definitely stuffed when I pulled it off, but I suspect its been replaced as a unit just for that and the motor itself is probably fine.
Will be a good score if that's the case.
1st Nov 2018, 08:58 AM #20Most Valued Member
- 4,258
Horizontal bandsaw questions
By Lovey71 in forum METALWORK GENERALReplies: 49Last Post: 10th Oct 2020, 04:49 PM -
3 Phase Generator Motor Powered by Single Phase Motor?
By gazza2009au in forum ELECTRICALSReplies: 49Last Post: 4th Apr 2020, 04:38 PM -
Lathe motor upgrade questions
By oohsam in forum METALWORK GENERALReplies: 15Last Post: 25th May 2016, 12:01 AM -
Is a motor start relay switch needed for a 3ph 2.8kw pump motor?
By Ben Dono in forum METALWORK GENERALReplies: 26Last Post: 14th Aug 2015, 02:38 PM -
Replacing A Single Phase Motor With A Three Phase Motor....................
By matthew_g in forum METALWORK GENERALReplies: 26Last Post: 1st May 2015, 04:42 PM
