Results 1 to 15 of 20
Thread: Bandsaw motor questions
12th Oct 2018, 01:47 PM #1Most Valued Member
- 2,651
I had an ancient Thiel vertical bandsaw follow me home the other day. Needs a bit of work but hopefully be a useful addition to the workshop.
Just wanting to clarify my thoughts on the motor. It's a 415v 3ph 1hp. Data plate says it's a star motor, and there are only 3 leads coming out to the terminal block.
I was thinking I might take my first dip into VFDs and install one on the saw instead of running it from my RPC, but looks like it would require delving into the motor innards to be able to convert it to delta (if it's even possible).
Am I on the right track?
12th Oct 2018, 03:07 PM #2Member: Blue and white apron brigade
- 7,182
If you connect a 240V VFD up to the motor "as is" it will generate about 1/2HP - this will be plenty to cut most sheet/plate, and smaller rod and tube.
To get the motor producing the original 1HP the motor will need to be converted to delta inside the motor.
Just a word of warning, if you are hoping to generate variable speeds using the VFD (this is very handy as it would then be much faster at cutting sheet material) I found old motors don't like being driven too far beyond 60Hz. One motor from an old DP would simply not go beyond about 65Hz.
It may be cheaper and easier to swap the motor out to one that is already convertible inside the connection box.
12th Oct 2018, 05:48 PM #3Most Valued Member
- 2,651
Thanks Bob. Good to know I'm sort of on the right track.
I hadn't thought much about the variable speed aspect and was more focused in the flexibility of being able to plug it into a normal single phase 10A outlet rather than having to use the RPC. Variable speed would be nice but not a show stopper.
The external wiring is cactus at present as the old rubber insulation has completely perished in places so I haven't been able to test if the motor even runs!
I guess the practical way forward is to hook up some good cable and test that first. If its stuffed then I'll need a new motor anyway so will just source one that can be run in delta with a VFD - or just convert it to single phase.
After having a 9" Hercus lathe with a 1/4hp washing machine motor for 30+ years I've lost interest in nursing underpowered machines, so probably wouldn't bother with the VFD unless I can get full power out of it.
Any idea how much digging might be required internally to find the star point on this style motor?
12th Oct 2018, 06:42 PM #4Member: Blue and white apron brigade
- 7,182
Sure I understand.
a) between the coils - this should be the same otherwise there is a prob and motor will run hot.
b) from the coils to ground - this should be MEGA ohms if not the insulation could be on its way out. A proper Megger tester should be used but a multimeter reading on Ohms will give you some indication
After having a 9" Hercus lathe with a 1/4hp washing machine motor for 30+ years I've lost interest in nursing underpowered machines, so probably wouldn't bother with the VFD unless I can get full power out of it. Any idea how much digging might be required internally to find the star point on this style motor?
Tricky Y common point excavation
This thread might also be useful as it shows a bunch of VFD installations, pros, cons etc
VFD install summaries
13th Oct 2018, 02:40 PM #5Diamond Member
- Aug 2006
- 1,105
I am with BobL on this, I would just source a modern motor, that thing is ancient. You would be able to pickup something up for less than $50.
13th Oct 2018, 03:40 PM #6Intermediate Member
- Jan 2009
- Auckland, NZ
- 32
You can get 240v in 400v out VFDs. I put one on myRF30 drill mill a few weeks ago. Works a treat. It is this one. https://www.aliexpress.com/item/Prom...27424c4dQHn2FE
about$A300 or $NZ 331. This saves mucking around with the windings.
13th Oct 2018, 04:47 PM #7Member: Blue and white apron brigade
- 7,182
4KW is over kill for his BS
This one might be better.
https://www.aliexpress.com/item/Inve...ceBeautifyAB=0
@ AU$240 - It is still cheaper to buy a 240V, SP - 240V, 3P, VFD and a used 3P motor that is convertible and would be able to operate over a wider frequency range.
14th Oct 2018, 08:12 PM #8Senior Member
- 112
I'm not sure why you have so much enthusiasm for a VFD on a bandsaw. Surely, unlike a lathe, mill or drill, there is no compensation required for the size of the work or cutter. I would suggest your best solution is for a 240V single phase motor of 1HP or perhaps 1.5HP to replace the existing 3 phase motor. There are several sellers on ebay, or you could buy a used one for a lot less than a VFD/motor combo. Just my opinion.
Chas.
14th Oct 2018, 09:24 PM #9Member: Blue and white apron brigade
- 7,182
I have seen charts that show different speeds for different sizes of work but perhaps more significantly are the optimum band speeds for different materials
Here are some typical band speeds (in ft per minute)
SS 75 -115
Carbon Steel 190-340
CI 110 - 250
Al 400 450
Some of this is about band longevity which matters less in a DIY situation
15th Oct 2018, 08:56 AM #10Senior Member
- 112
Thanks for the information, Bob. It is always good to learn something new. My remarks were in the context of a woodworking bandsaw, due in part to what appears to be a layer of sawdust on the motor as shown in the photos. I now know that a Thiel is a metalworking machine, and was possibly two speed. More details always welcome.
Chas.
15th Oct 2018, 09:21 AM #11Member: Blue and white apron brigade
- 7,182
To a certain extent WW working bandsaws can also use a VFD. The optimum speed for ripping timber is around 5000 ft/min whereas most WW bandsaws run at no more that 3300 ft/min. I have experience with this running a 27HP Bandsaw mill cutting logs up to 35" wide and can the higher speeds really makes a difference in cutting speed. The reason the higher speeds are not used on smaller bandsaws is these band speeds are pretty frightening and potentially more dangerous and when cutting short pieces is unnecessary.
I put a 3HP motor and a VFD on my (originally 2HP) WW BS a few years ago and it has a speed range of 1000 to 5000 ft/min and confirm it can cut faster at higher speeds. Another advantage of a VFD is it can also be used in conjunction with a braking resistor to rapidly slow down a BS. I did this on a radial arm saw at the mens shed which used to run silently for more than 2 minutes after it was turned off. Now it stops in 4 seconds. I put a foot brake on mine a few years ago and that stops the band in about 3 seconds so I don't need that feature on a VFD.
15th Oct 2018, 12:35 PM #12Most Valued Member
- 2,651
Thanks guys - some great info ideas there.
Haven't had a chance to look any further at the motor yet, but did take the opportunity to buy one of the cheap electronic meggers off ebay as I know its something that I'll definitely use again. I need to chase up my father and see if he's still got a real megger from his sparky days that he no longer needs (he lives in NZ otherwise that would have been my first option).
Regardless of which way I end up going with this particular machine, I'd like to know whether the motor itself is any good. Its also a perfect opportunity to learn a bit more, as I'm sure this won't be the last dodgy old motor I ever deal with
Will update once I've the megger arrives and I've had a play with it.
17th Oct 2018, 02:06 PM #13Most Valued Member
- 2,651
Still waiting for the megger to turn up, but just did a quick check of the winding resistance and get around 18ohms between each of the terminals.
Shows open circuit between terminals and ground on a standard digital meter (2000K max range).
17th Oct 2018, 09:50 PM #14
Hi Steve,
It would certainly benefit from a good strip and clean up. If you are going to attempt to dig out the star point, be very wary of the state of any insulation in there. You could find that it might have been better just to retire it !Best Regards:
23rd Oct 2018, 06:54 PM #15Most Valued Member
- 2,651
The megger arrived today.
Checked out the motor - getting around 47Mohms between the windings and motor body.
Horizontal bandsaw questions
By Lovey71 in forum METALWORK GENERALReplies: 49Last Post: 10th Oct 2020, 04:49 PM -
3 Phase Generator Motor Powered by Single Phase Motor?
By gazza2009au in forum ELECTRICALSReplies: 49Last Post: 4th Apr 2020, 04:38 PM -
Lathe motor upgrade questions
By oohsam in forum METALWORK GENERALReplies: 15Last Post: 25th May 2016, 12:01 AM -
Is a motor start relay switch needed for a 3ph 2.8kw pump motor?
By Ben Dono in forum METALWORK GENERALReplies: 26Last Post: 14th Aug 2015, 02:38 PM -
Replacing A Single Phase Motor With A Three Phase Motor....................
By matthew_g in forum METALWORK GENERALReplies: 26Last Post: 1st May 2015, 04:42 PM
