Results 1 to 3 of 3
29th Sep 2018, 04:40 PM #1Golden Member
- Jul 2011
- 837
2 Speed three phase motor replacement with vfd on a lathe.
The original motor was a 2/4 pole motor so what is best to replace it with if requiring the same range as before? 4 pole motor (and run it at twice rated speed sometimes) or 2 pole motor (and run it as half rated speed sometimes)?
29th Sep 2018, 04:54 PM #2Philomath in training
If you run a (nominal) 50Hz motor at 25Hz, you will have less torque and need additional cooling as the fan on the back (if it has one) will not supply enough cooling for the motor. On that basis, I would go for 4 pole and run it faster some times. My lathe will run to 2200rpm but I must admit that most times I don't run much over 1000 to 1500rpm. At least you will have the low down torque, handy for screw cutting and other demanding tasks.
29th Sep 2018, 06:19 PM #3Member: Blue and white apron brigade
If you install a motor that has 2x the original motor power and use a 4 pole motor and a V/F VFD you should have at least the original power between 25 and 125 Hz.
That's at least a 5:1 speed range.
At 125Hz a 2 pole is doing ~7200 RPM - which is a bit much for most two pole motors.
At the same frequency a 4 pole is only doing 3600 RPM which is well within spec for most motor bearings and rotor safety
If you also use a vector drive VFD you should have at least the original power between 12.5 and 125 Hz.
That's 10:1 speed range.
It's unusually to need extra cooling at 25 Hz but you will need it for 12.5Hz.
3 Phase Generator Motor Powered by Single Phase Motor?
By gazza2009au in forum ELECTRICALSReplies: 49Last Post: 4th Apr 2020, 04:38 PM -
Replacement lathe motor
By GeoffW1 in forum ELECTRICALSReplies: 4Last Post: 6th Sep 2016, 07:10 PM -
Another interesting option for lathe/mill motor replacement
By PDW in forum METALWORK GENERALReplies: 6Last Post: 20th Jan 2016, 09:30 AM -
Replacing A Single Phase Motor With A Three Phase Motor....................
By matthew_g in forum METALWORK GENERALReplies: 26Last Post: 1st May 2015, 04:42 PM -
Looking to swap a 2Hp single phase motor for 1.5 or 2Hp 3-phase motor
By jhovel in forum METALWORK GENERALReplies: 7Last Post: 10th Mar 2014, 07:26 PM
