Results 1 to 8 of 8
    Apr 2012
    Healesville
    2,129
    Default Battery ? 600mm digital caliper
    I couldn't buy batteries for this in my town, got the mrs to pick some up for me from elsewhere, they had differant numbers and were too small so i got some off ebay, yup still too small ?grrr
    I had a bit of a search and it seems that similar calipers to this use a CR2032 battery, i have one here but i am not sure whether or not to put it in as it is a 3v batt and 1.5v is what the sticker on the back states, the instruction sheet only says to put a battery in it without mention of the type.
    I think that the battery type on the sticker is wrong but before putting the 3v in i thought i would see if someone here could shed some light on this.
    Cheers, shed
    Apr 2012
    Healesville
    2,129
    I just re read the instructions and it says to use a 1.5 volt batt but does not give a battery number.
    shed
    Nov 2007
    melbourne australia
    3,228
    Deleted
    Jul 2016
    35
    1,522
    I would put the 3v in, I don't think you'll smoke anything. although I notice Jaycar do stock 1.5v sr44s
    6,473
    Hi Shed,
    I would say if the battery holder is the right diameter for a CR20xx then put it in ! Just bear in mind that this battery comes in three thickness’s.
    The first number is the diameter 20 mm, the last two are the thickness, 32 = 3.2 mm, 20 = 2.0 mm and 16 = 1.6 mm.
    The most common is the CR2032, which is used in computers for on board memory retention. They are all 3 volt batteries.
    Dec 2013
    Mt Waverley Vic 3149
    81
    44
    Jaycar have sr44 equivalent -Chech your 2nd photo - state battery sr44
    https://www.jaycar.com.au/search?tex...6-b89707f22ed0
    Bob
    Apr 2012
    Healesville
    2,129
    I have been to jaycay, the SR44 battery is too piddly, I have a SR44 in the picture up above sitting on the caliper just above the battery hole.
    I don't think I wanna put the 3v in it just yet.
    Apr 2012
    Healesville
    2,129
    I sent a message about this to the seller, the answer was CR2032.
    thanks fella's
  1. Digital caliper inaccuracy????
    By GDD in forum METALWORK GENERAL
    Last Post: 8th Sep 2018, 11:39 PM
  2. Replies: 3
    Last Post: 29th Oct 2013, 11:03 AM
  3. What's a good brand of digital caliper?
    Last Post: 1st Nov 2011, 02:12 PM
  4. SOLD: Digital Caliper 150mm
    By krisfarm in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 1st Dec 2010, 04:43 PM
  5. Question about battery life in digital calipers
    By familyguy in forum METALWORK GENERAL
    Last Post: 29th Mar 2009, 12:29 PM
