Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    May 2011
    Murray Bridge S Aust.
    5,959
    Default Sewing machine variable controller
    I'm in a position where I need to make a miniature welding rotator. Thinking of using a sewing machine motor to power it, but would need a variable switch to get the RPM right, would a fan control switch or light dimmer switch be sufficient to do it. The drive will be by toothed belt, so as not to interfere with the motor side of things
    It'll be running a 4" 3jaw chuck and welding a bolt on the end of 15NB pipe, have several hundred of them to do, not all at once, thank God!!!!!
    6,480
    Hi Kryn,
    Here you go !
    I know it says 230 VAC, it will happily work on 110 as well should you need it to.
    C1, C2, R1 and L1 are interference suppression components. The circuit will work just as well without them.
    If you get noise on your radio when running then include those components.
    7,189
    What sort of motor is it motor and what RPM do you require?
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    My thoughts too. I would have thought for welding you would want something around 60rpm perhaps +60, -30rpm. A sewing machine motor is not going to do that straight out of the box. If the only thing you are doing are these bolts, perhaps a pin on a base plate and a socket on top of that would be enough to do the job (rotate by hand - use an old steering wheel, pulley or something similar)
    7,189
    Sewing machine motors are typically in the 6 to 10k rpm range so to get 30rpm requires at least 200:1 reduction. Doing this electrically is a big ask so you will need some mechanical reduction before hand. Even if you can get a 10:1 mechanical reduction that still leaves a 20:1 reduction electrically which is 95% speed reduction where the motor may have little or no torque left to drive any load.
    If you wanted to pursue this I'd be looking at a 12/24V DC motor with a full reduction gear box as they go for about $20 on ebay..
    Sep 2010
    Lebrina
    1,915
    Do you have access to a straight line oxy cutter? They make brilliant rotators as all the work has been done for you and you just need to mount a chuck or plate on the drive wheel.
    Oct 2015
    melbourne
    473
    Hmmm
    Are we talking domestic motor or industrial?
    A domestic sewing machine foot controller lets you sew really slowly.. Down to a single stitch at a time. And the old ones are just a variable resistance.
    Sewing machines don't have a massive reduction inside. A universal motor does have good torque at low speed.
    But your weld positioner will probably have a lot more mass than a sewing machine, so you should aim for as much reduction as you can arrange.
    Russ
    May 2011
    5,959
    Hi Kryn,
    Here you go !
    Thanks for that John, only problem is that, to me it's just squiggly lines and black triangles.
    Electronics ain't my field/interests.
    The reason I mentioned using a sewing machine motor, is that I have several of them, didn't think that they ran that fast though.
    Oh Well, back to the drawing board, might look at microwave motors, as they run about 3 rpm, which should be enough.
    Thanks everyone for their comments.
    6,480
    Hi Kryn,
    OK point taken I won't suggest a light bulb dimmer switch then, which would also work.
    You could look at an oven rotisserie motor ! I don't think you will get anyway near enough torque from a microwave turntable motor.
    Jun 2010
    Canberra
    1,322
    What about an old cordless drill with a 2 speed gearbox? In low gear and with the trigger only just depressed, they go pretty slow. You could also drop the supply voltage to go even slower.
    May 2011
    5,959
    Thanks for that Rusty, as I mentioned to John, electrics is not a field that I'm familiar with nowadays, so I'd like to stay away from voltage reducing equipment.
    Was hoping to do a plug and play sort of thing.
    10 years ago I wired up my shed, can't remember how to do a light switch now.
    Oct 2011
    59
    6,561
    If you had a lathe, you could chuck up a broomstick (insulator) and then support the free end in a bush. Cover the bed, attach the chuck to the end of the broomstick and put it on a slow speed and you might just be able to do it.
    Failing that, I do have surplus spankers 20:1 gearbox here.
    May 2011
    5,959
    Thanks for the offer, Michael. How big is it, shaft sizes, etc.and how much do you want for it?
    Aug 2006
    1,106
    Quote Originally Posted by Karl Robbers View Post
    That is actually a really good idea Karl, never thought about that before.
  15. #15
    May 2011
    5,959
    Thanks for the idea Karl.
    I don't have access to one but looked on gumtree and found one at a respectable price, no nozzle or track, not that I need them ATM.
    Waiting on a reply from the seller. They're not a cheap item!!!!
  1. Motor Speed Controller
    By barkersegg in forum ELECTRICALS
    Last Post: 23rd Aug 2018, 08:49 AM
  2. Mill motor controller !
    By BaronJ in forum METALWORK GENERAL
    Last Post: 14th Jul 2017, 01:51 AM
  3. Electromagnetic chuck controller
    By .RC. in forum METALWORK PROJECTS
    Last Post: 15th Dec 2016, 11:39 AM
  4. Variable speed motor and controller
    By Jim Ferrous in forum METALWORK GENERAL
    Last Post: 24th Sep 2013, 03:03 PM
  5. cheap foot TIG controller
    By WelderMick in forum WELDING
    Last Post: 17th Jan 2011, 01:33 PM
