Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 60
  1. #31
    Apr 2012
    Healesville
    2,129
    Default ISACON - HY Series VFD
    Yup.... its not a Huanyang.
    I thought it a bit odd as there is no manufacturer name on the VFD and also not obvious on or in the booklet
    that came with it, the name "ISACON" (chinglish for "is a con") is only to be found in a paragraph about warranty.
    I thought okay.... before I hang that book on the nail in the dunny I will read it even tho I don't know what it means.
    I got to "Pn 04 Source of runtime command with range, 1 - 2"
    hmmmm...????...tick tick tick clunk tick tick squeal tick tick tick..???....... Ahhhh Sssooooh......maybe runtime = go????
    YIPPEE
    You lose the reverse button but for what I want here that is cool and I only have 2 wires for each VFD to remote stop and start.
    So its a whizzer
    cheers from a very happy shed
    and, ah tho....need click click switch not momento switch.
  2. #32
    7,189
    So much joy from such a simple thing - love it.
  3. #33
    Feb 2018
    Florida, USA
    20
    make the VFD enclosure
    thanks, shed
    Shed
    You fellows seem to have a good idea of what you are doing. If I might I would like a little help on wiring a remote control panel on the mill. I have a 2 hp 3 phase on my mill and I would like to wire it up to make it more convenient when working. The Attached thumbnail is exactly the same as mine but mine is 220 single input and 3 phase output. The second picture with all the terminals needed is the same. Any help would be more than appreciated.
    Nelson
  4. #34
    Apr 2012
    Healesville
    2,129
    Hi Nelson, l dont see any pics?
  5. #35
    Jun 2007
    Vic
    48
    544
  6. #36
    Feb 2018
    Florida, USA
    20
    Hello All
    I would like to wire up my VFD so I can operate it from on the machine instead of at the VFD. In this write up I've seen VFD like mine and I just need some help in what I need to do to get it done. Here are the pics of my VFD, several pages from the manual and hope I got enough to get me home.
    Thanks for all the patience and help.
    Nelson
  7. #37
    Feb 2018
    Florida, USA
    20
    Shed
    The pic are on the forum now and if I could get some help I would be so thankful.
    Thank you.
    Nelson
  8. #38
    Feb 2018
    Florida, USA
    20
    Quote Originally Posted by Nrcollar View Post
    Hello All
    Nelson
    When I took the pics I got the wrong one for the wiring figure. It was this one that is posted earlier in this thread.
    This is the right picture and when using 220 volt single phase you use the "R" and "T" leads.
    The VFD is in operation, I would just like to use my converter with a remote panel, not the factory panel. The buttons will fail soon or later.
    HELP.
    Nelson
  9. #39
    7,189
    Nelson, the circuit diagram is self explanatory.
    If you cannot work it out from the diagram that indicates to me that you may not be able to follow any advice provided through this forum either.
    Perhaps you should hire someone to do it for you.
  10. #40
    Oct 2015
    melbourne
    473
    You will need to think about what functionality you want - just run/stop? Reverse? Variable speed? Jog?
    Its not complicated as such, but as Bob called out, if the diagram is not clear to you, then you probably do need someone on hand to sort it for you.
    I'm sure though you can build up the actual remote console.
    240v is not something to learn electronics on....
    Russ
  11. #41
    Feb 2018
    Florida, USA
    20
    Russ
    It is not the 240v I am dealing with. 5 to 12 volt is not that dangerous. I wired in the Potentiometer, it works fine and I do not see anything special about the switching. Are they just a push button switch?
    Thank you
    Nelson
  12. #42
    Jun 2010
    Canberra
    1,322
    From the wiring diagram, it looks like the buttons should be momentary action.
  13. #43
    Feb 2018
    Florida, USA
    20
    Rusty
    Thank you and I guess I just needed some conformation.
    I do not understand the resistance from some. If I fry the unit it cost me, if it kills me because of my stupidity it is my fault. I did not get to be 60+ and not learned to be safe.
    Thank you so very much Rusty. I get my panel together and post a pic soon.
    Nelson
  14. #44
    Apr 2012
    Healesville
    2,129
    Hi Nelson, that looks like the same inverter that i am using, you will need toggle switches and will need to change the setting"Pn 04 Source of runtime command with range, 1 - 2" to get those terminals to operate.
    I will get my manual from the shed tomorrow and if you have questions i might be able to help.
    cheers, shed
  15. #45
    Feb 2018
    Florida, USA
    20
    Shed
    Thank you so very much. I have got the programming down, it was just the kind of switch to use? Now you say toggle and what I have read it is momentary? Confusing.
    Nelson
  1. Cable disc brakes routing of cable.
    By gros21 in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 14th May 2017, 06:41 PM
  2. Vfd control panel
    By russ57 in forum ELECTRICALS
    Last Post: 29th Mar 2017, 01:19 AM
  3. Milling machine control panel issue
    By oohsam in forum METALWORK GENERAL
    Last Post: 23rd Dec 2016, 08:13 PM
  4. VSD Remote Control Panel Questions
    By markjaffa in forum METALWORK GENERAL
    Last Post: 20th Apr 2010, 05:15 PM
  5. 7 x14 control panel puzzle?
    By Malfie in forum METALWORK GENERAL
    Last Post: 11th Jul 2007, 11:35 AM
