Results 16 to 30 of 60
Thread: VFD control panel cable ?
12th Jul 2018, 08:54 PM #16
Hi Shed,
From the diagram all the switches look to be momentary ones.Best Regards:
12th Jul 2018, 09:41 PM #17Member: Blue and white apron brigade
- 7,183
The diagram is most likely misleading.
My experience is none of the VFDs I have will stay on or turn off using just momentary switches but maybe there is a way to program this. In fact repeated use of a momentary switch just result in a VFD error. A momentary switch has to be linked to a latching switch using another power supply and the output of the latching switch connected to the VFD.
The main reason there I haven't persued momentary switches is because its state cannot be determined by a quick glance of teh switch position ie whether it's supposed to be on or not. I like using switches that have a physical position then a quick glance will confirm if it is supposed to be on on not. I don't even like using LED backed switches as the lights could fail and colour confusions can even add the complexity. The 3 Mile Island reactor coolant system failed because of colour coded light indicator inconsistencies on pump switches.
That's why I have standardised on a 3 way toggle switch with up for forward, middle for off and down for reverse in my shed. Some say that this makes it too easy to go from forward to reverse. In the 7 years on the 4 machines that have this setup in my shed this has happened to me once. This was on my ww lathe where initially I had the switch wired the other way ie down was fwd and during a small emergency not long after I first wired it up I flipped the switch the other way and got it into reverse.
12th Jul 2018, 10:52 PM #18Most Valued Member
- Healesville
- 2,129
I hear what you are saying Bob but I think that tomorrow I will wire a VFD up and try a momentary switch and see what happens, this part of the diagram seems to indicate that the latching circuit that you are talking about may be
included in the circuitry in the VFD?
If it does work it looks to me that one push starts and another push stops, if that does work then I would only need 2 switches, 1 for each VFD as don't need to reverse either motor.
It couldn't be that easy, surely
Thanks, shed
13th Jul 2018, 12:18 AM #19Member: Blue and white apron brigade
- 7,183
13th Jul 2018, 04:18 PM #20Diamond Member
- Aug 2006
- 1,105
It normally is a programming option or some VFDS require an additional relay. Otherwise the easiest way is the way that Bob has done it.
13th Jul 2018, 05:57 PM #21Most Valued Member
- Healesville
- 2,129
Nup, it didn't work.
Think I might try to contact the manufacturer so I had better brush up on my chinglish
No 1 T & C grinder, for the wheel so I can vary the speed for different dia wheels.
No 2 is for the work head motor to slow it down, it goes too fast for larger jobs and I spend a bit of time
balancing drive dogs ect.
No 3 is for a water cooled spindle motor for internal grinding, need to make the mounting plate for this.
No 4 I put a 1hp 3ph motor on my little Centec mill, seems to work well but I still have to sort leaking oil seals
and and some other minor things.
No 5 just coz
13th Jul 2018, 07:16 PM #22Member: Blue and white apron brigade
- 7,183
Good luck.
For the HY VFDs I have in the past repeated scoured the e-version of the manual for a reference to momentary switches but could not find anything.
No 5 just coz
It's all water under the bridge now but with such small motors these would have been prime candidates for the Powtran 130/160 series VFDs - they have an excellent manual, are fully featured (ie Vector drive) and more intelligent than standard HYs, half the physical size of the HYs, and they cost about the same as the HYs.
The 1HP PI130 and the 0.5HP PI130 are the two I used on my mill. The 2HP 160 has gone onto my DP - it has a 1.5HP motor.
The 3HP PI9130 is a super piece of kit - I bought it here in Perth as never used item on ebay and then found out I could have bought it slightly cheaper direct from the Powtran factory.
I was going to use the 9130 on my dust collector but I upgraded it to a 4HP motor and already had a 4HP HY in my stash so used that - it's not like it needs a lot of low speed grunt/control/intelligence running a DC.
13th Jul 2018, 07:26 PM #23Diamond Member
- Aug 2006
- 1,105
Do you have a link for the HY manual?
13th Jul 2018, 07:39 PM #24Member: Blue and white apron brigade
- 7,183
13th Jul 2018, 08:18 PM #25
Just refreshing some info for remote panel for HY VFDs:
This is the 'complete' set for two stopping settings (the really fast emergency stop will only work with an external brake resistor).
But you can use any of the switches or settings from the diagram that are convenient and just leave the others off.
and a suitable switch layout:
PM me for manuals if you need one.Cheers, Joe
13th Jul 2018, 08:29 PM #26Member: Blue and white apron brigade
- 7,183
Thanks Joe - very helpful.
I'm slightly confused by the stop/run labels on/under the red button.
Is that like single start/stop button? push to start, push it again to stop?
Or is FWD = start and Stop is just stop?
13th Jul 2018, 08:49 PM #27Member: Blue and white apron brigade
- 7,183
I have found Joe's equivalent circuit in the Manual. Easy to find when you've seen it somewhere else,
This still looks like separate buttons/swtches are needed for stop and start
15th Jul 2018, 01:03 AM #28
Yes, I agree. It's confusing.... The bottom row indicates the 'RUN' line versus the 'JOG' line and gives directions..... ALL BUTTONS are momentary. So you touch the FWD button and it runs, touch the stop button and it stops. Touch the Jog buttons and it runs at 5Hz until you let go. Just for checking celarances and for running a dial incdicator - I us that ALL the time, I find.....
The E-Stop at the top triggers the 0.1sec braking ramp and stops my lathe from flat out at 120Hz in less than 1.5 revolutions with screeching belts. At 50Hz it just stops dead and nearly jumps of the floor! I have never used it in earnest, but test it occasionally. Always frightens the crap out of me, despite knowing what will happen.....
No relays needed at all.Cheers, Joe
15th Jul 2018, 01:07 AM #29
Yes, that is correct. The other version in the manual shows the On/off switches: one for run/stop, the other for forward/reverse.
I have used both options. The motorised workhead on my cylindrical grinder seemed better suited to on/off and fwd/rev switches to me...
Horses for courses.....Cheers, Joe
15th Jul 2018, 03:35 PM #30Senior Member
- Oct 2015
- melbourne
- 473
The manual may refer to 'edge' triggers or 'level' triggers -rather than momentary switches or normal on/off switches.
And there will be a setting somewhere which sets the option you want.
Russ
Cable disc brakes routing of cable.
By gros21 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 3Last Post: 14th May 2017, 06:41 PM -
Vfd control panel
By russ57 in forum ELECTRICALSReplies: 7Last Post: 29th Mar 2017, 01:19 AM -
Milling machine control panel issue
By oohsam in forum METALWORK GENERALReplies: 33Last Post: 23rd Dec 2016, 08:13 PM -
VSD Remote Control Panel Questions
By markjaffa in forum METALWORK GENERALReplies: 28Last Post: 20th Apr 2010, 05:15 PM -
7 x14 control panel puzzle?
By Malfie in forum METALWORK GENERALReplies: 3Last Post: 11th Jul 2007, 11:35 AM
