Results 1 to 4 of 4
    Jul 2010
    Brisbane
    143
    Default testing 415 V motors
    I have several 415V 3 phase electric motors that I want to sell.. but It would be nice to see if they actually work first !..apart from plugging them in to someones factory, is there any other way to see if they are working ?
    Ken
    6,481
    Hi Ken,
    As a first step, you will need a megger, is to check for any winding insulation breakdown to the case ! If they have an earth connection, check continuity to the metal frame. After checking that, then applying a three phase source to see if they run quietly without bearing rumbles. The three phase source could come from an inverter, single phase in, three phase out.
    7,189
    As well as BJs recommendations the winding resistances should all be identical.
    Even though they are 3P 415V they will still run on a 3P 240V VFD - they just won't develop full power.
    6,481
    Thank you Bob, Yes I completely forgot to mention that. Sorry.
    The only thing I would add is take extra care when measuring multi speed motors ! It is easy to make an error comparing multiple windings.
  1. Multiple motors from one VFD
    Last Post: 10th Jan 2016, 07:58 PM
  2. Treadmill Motors.
    By j.ashburn in forum METALWORK GENERAL
    Last Post: 24th Sep 2013, 08:22 AM
  3. CMG Motors
    By GSRocket in forum METALWORK GENERAL
    Last Post: 21st Aug 2012, 11:19 PM
  4. Swarf & Motors
    By toolman49 in forum METALWORK GENERAL
    Last Post: 28th May 2011, 11:01 PM
