Results 1 to 13 of 13
    Aug 2015
    Melbourne, Australia
    843
    Default Delta wire bridgeport motor
    Hi all,
    A new-to-me Bridgeport followed me home yesterday. 2hp 3 phase.
    The motor terminal box wiring looks like this:
    very neat. I figure this means it can be re-connected for delta so I can run it on a VFD? Maybe it already is delta (but as the machine just came from an industrial toolroom I doubt it).
    I guess the next question is, if it can - any hints on how to reconnect the above?
    All forum disclaimers apply.
    Many thanks,
    Greg.
    Aug 2015
    843
    After some kero and scrubbing, the rather obscured plate revealed itself.
    It looks like the 'lo volts' might be the connections for delta?
    That what you are looking for Bob?
    Greg.
    7,188
    That is exactly what I was hoping for - am also hoping the wires themselves are numbered?
    I assume you have a single phase input 220/240V VFD?
    In that case you should wire it for the Low voltage.
    The "MUST be a delta" is not necessarily the case, and only applies to to motors that are initially 3P ~415 "Y" connected and need to be run on 240V 3P.
    When these motors are converted to ∆ this automatically makes them a 240V 3P capable motor.
    For example take teh opposite, a 415V ∆ connected machine won't develop full power when connected to 240V 3P even though it is already a delta. Conversion to a Y will mean this motor will require about 800V 3P to develop full power.
    BTW, if you were to wire the motor to high voltage is should (no guarantee mind you!) not let out any smoke and it should still run but it will only develop half power.
    If you have not used that VFD before I suggest you wire it to another 3P motor and check that it works properly before trying the mill motor otherwise you will be dealing with a double blind situation.
    BTW Am dead jealous of your deal! - the only consolation I have is that there is no way I could fit such a machine inside my shed.
    Aug 2015
    843
    Thanks Bob. Much appreciated.
    Yes, I have a 2hp 240v VFD - and I have used on it some other motors - so she's good.
    I'm neck deep in crud cleaning it at the moment so I'll check the wire numbering a bit later. When it comes to wiring it up to test it I may need some more advice on what wires from the 5 core to use.
    Re the deal on the machine. Thanks. ) I have been looking some quite some time but it had to make sense before I bid. For example, not long ago someone paid $6500 on greys for a series 1. Add on 15% buyers premium and they forked out about $8k for it. Holy moly.
    Despite being quite a lump it doesn't actually take up too much more space than the Herless knee that it'll replace.
    Thanks again.
    Nov 2008
    Sydney
    112
    Quote Originally Posted by StrayAlien View Post
    Greg.
    According to my understanding of the motor connection diagrams on the nameplate, the motor is star connected for either 440V or 220V. The windings to (7), (8), and (9) are internally connected together as star. The other set of individual windings (1) - (4), (2) - (5), and (3) - (6) are either jumpered in series with the star set to provide a 440V star connection, or they are jumpered for star (4)-(5)-(6) and connected in parallel with the star set of windings for 220V.
    Hope this helps, Chas.
    7,188
    You'll need more specific advice from someone who knows about mills and Bridgeports.
    My understanding is that Bridgeports have other motors on them like the table motion motors and a coolant pump motor
    My question is, are these 3 or single phase motors?
    If they are single phase it will be far easier to strip out all the 3P wiring and switches off the machine and rewire it all using single phase line.
    If they are 3P things will get complicated if you use the same wring and my preference would be to instal a separate single phase line and safety switch to control the VFD/motor and runs all the the stuff from 3Phase. You can't use a single VFD to run all these motors
    Aug 2015
    843
    Chas, thanks. No delta in there? Is that what you mean?
    Bob, thanks also. 'Luckily', this garden variety BP has no shmancy extras. Just the motor - no power feed or coolant motor.
    EDIT: the DRO has its own 240 SP plug, but a curious red wire is wound around the top of a screw on the mill power box and then attaches to two points on the DRO unit.
    7,188
    Good in that case strip off all the old wiring and switches and start again.
    How about some pics?
    Nov 2008
    Sydney
    112
    [QUOTE=StrayAlien;1933465]Chas, thanks. No delta in there? Is that what you mean?
    Yes, no delta option; the motor is wired either 440V star (HI Voltage) or 220V star (Lo Voltage). I would think your VFD will work into 220V star, but I cannot speak from experience.
    Chas.
    Aug 2015
    843
    Bob, pics. The red wire connected to nothing in the power box so I'm guessing it might be an earth using some convenient red wire .. ?
    And re throwing it all out:
    Not a chance!
    Chas. Thanks. disclaimer: I am quite an idiot with electrics. My small brain had equated 'star = bad, delta = good' for running a VFD on 240. But, your message is sinking in ... 240 star should be just a good. Basically, who cares .. it is 3P running on 240.
    I checked the wiring. It is numbered. Twice! Each wire not only has the number word on it like (say) 'seven', but also a string of 7's down the edge of the wire as well. Nice.
    I'll give it the VFD smoke test in the next day or two.
    Greg.
    Aug 2015
    843
    Actually, I gave it a test just now. Rewired stuff according to the plate and it runs just fine on the 2hp VFD. The forward/reverse switch also works.
    Nice. Thanks Bob . Thanks Chas.
    Greg.
    7,188
    Good work.
    Red wire on DRO - exposure like that does look lake an earth - pretty foolish using a red wire though.
    Second picture of the red wire at the back of the DRO.
    Can you follow that red wire that heads off out of the picture.
    What make/model is your VFD and is it a Vector drive?
    Nov 2008
    Sydney
    112
    Up to the 1960's, red was the designated colour for AC earth wiring in Germany. Perhaps the wire on that VFD had its origins in that country, or someone from there?
    Chas.
  1. Motor hard wired for Y - therefore no delta?
    By StrayAlien in forum ELECTRICALS
    Last Post: 24th Nov 2017, 11:22 AM
  2. ASEA motor Y to delta conversion.
    By da9jeff in forum ELECTRICALS
    Last Post: 27th Feb 2017, 11:36 AM
  3. Replies: 68
    Last Post: 22nd Jun 2015, 09:25 PM
  4. Replies: 68
  5. Star/Delta motor wiring
    By .RC. in forum METALWORK GENERAL
    Last Post: 3rd Mar 2012, 11:01 PM
