Results 1 to 2 of 2
Thread: Generator from 3P motor
8th Mar 2018, 09:26 PM #1Member: Blue and white apron brigade
- 7,183
The mens shed finally had THE clean up they should have had a few years back. Five 3P electric motors were deemed disposable and I said I would try and sell them on GT. After 3 weeks of zero response, a bloke calls me and says he wants to buy one to make an electric generator.
Bloke comes around and says he's a welder and has seen how to do the conversion on You tube. Apparently the rotor is removed and turned down a bit so magnets can be glued onto the rotor. Then he's going to power it with a diesel engine. I immediately thought, What about balancing, and voltage reg? I keep very quiet and he buys a motor and then sees all the other motors and gear in my shed and says, you should turn all these motors into generators - good money to be made. Then he asks me if how much would I charge to turn down the rotor in his motor but I said I was too busy, and don't have insurance to cover this sort of thing. He clearly thought I was a bit of a wuss. I suggested he go to his local mens shed, but now I'm sorry I said that.
8th Mar 2018, 09:33 PM #2Most Valued Member
- 5,945
I once used a welder made from a 3P motor, don't know how it worked or what was done to make it work. It had a flat pulley on the end of the shaft that had a bar approx 1 metre long welded to it. To adjust the amps the bar was rotated slightly and locked in position.
3 Phase Generator Motor Powered by Single Phase Motor?
By gazza2009au in forum ELECTRICALSReplies: 49Last Post: 4th Apr 2020, 04:38 PM -
portable generator
By splinter56 in forum WELDINGReplies: 5Last Post: 18th Sep 2012, 08:31 PM -
AC motor generator article
By morrisman in forum METALWORK GENERALReplies: 0Last Post: 4th May 2012, 08:51 PM -
Air compressor & generator box
By steran50 in forum METALWORK GENERALReplies: 8Last Post: 11th Jul 2011, 07:54 PM -
Generator for Arc Welder help
By twebb01 in forum WELDINGReplies: 6Last Post: 3rd Oct 2009, 03:41 PM
