Results 1 to 3 of 3
    Aug 2015
    Melbourne, Australia
    843
    Default Motor hard wired for Y - therefore no delta?
    Hi all,
    I got a 3ph motor to install on the lathe with VFD (motor kindly donated by a forum member). But looking at it, I am guess this one is not delta configurable without getting into the guts of it? (which I am distinctly underqualified to do).
    all advice appreciated.
    Greg.
    7,189
    A motor rewinder should be able to do it but you will most likely find a suitable one on gumtree for less than half what it costs a rewinder to do it.
    The screw terminal behind the brown wire looks like it could be the common point - are there 3 wires running to that terminal.
    If so it will be much easier to convert as there is no need to open up the motor.
    I still recommend you get motor rewinder to do it as the motor rewinder will hopefully test the motor to make sure its worth converting.
    Aug 2015
    843
    Thanks Bob. Appreciated.
  1. ASEA motor Y to delta conversion.
    By da9jeff in forum ELECTRICALS
    Last Post: 27th Feb 2017, 11:36 AM
  2. Replies: 68
    Last Post: 22nd Jun 2015, 09:25 PM
  3. Replies: 68
  4. Star/Delta motor wiring
    By .RC. in forum METALWORK GENERAL
    Last Post: 3rd Mar 2012, 11:01 PM
  5. allowance for a wired edge?
    By techgirl in forum METALWORK GENERAL
    Last Post: 10th Aug 2010, 06:47 PM
