Results 1 to 7 of 7
    Aug 2009
    Sydney, NSW, Australia
    1,844
    Default DIY HF Arc Starter, Need elaboration on this idea
    Hi guys some may know i just picked up a antique tig welder and it is using incredible amounts of power over 50amps from the power point, i took into consideration my options of getting a dedicated 32amp line (i may move house, renting), i have thought about petrol generators (not cost effective), than i remember a diy high frequency arc starter being made the first one i seen used batteries but that idea i think has been removed from the internet
    but there is this type pictured
    i know they are using a car ignition coil but there is no further information on the design i can't seem to find a diagram of any of these diy models, can someone please elaborate on what the internal components are called so i can look them up and see how they work and do some research?
    cheers
    Jun 2016
    Batemans Bay
    75
    G'day Gazza,
    check this link out for the circuit diagram of that unit
    High-Frequency Start Box
    Steve.
    Aug 2009
    1,844
    Thanks Steve
    6,474
    Hi Gazza,
    I believe that one of the reasons that these units are no longer available, is that the high voltage can break down the welder transformer insulation. I have an old buzz box welder where one of these ionizers has been fitted and it has a low resistance to earth causing it to blow the mains fuse. Swapping the live / neutral wires or removing the earth connection allows the transformer to work, but it is dangerous to use like this.
    Aug 2009
    1,844
    I was thinking of buying one of these
    https://www.ebay.com.au/itm/Arc-Star...19.m1438.l2649
    the seller ships to Australia but by my calculations it works out about $150 AUD, Its not cheap to send anything out of the US to AU minimum like $30 USD
    6,474
    Hi Gazza,
    I had a look at that Ebay link. I did note that the UK is one of the countries not shipped to !
    The idea of an RF choke is good, but I don't know if that would be sufficient on its own. The idea is to prevent the high voltage RF from breaking down the welders insulation by choking it off before it can get back in there.
    Aug 2009
    1,844
    Baron, Australia isn't on the list either mate but i just sent the seller a msg asking if posting to Aust was possible he was more than happy to
  1. Bad Idea?
    By NedsHead in forum METALWORK GENERAL
    Last Post: 5th Oct 2017, 09:51 AM
  2. Where to buy non Chinese starter capacitors
    By Grahame Collins in forum METALWORK GENERAL
    Last Post: 17th May 2016, 09:45 PM
  3. What starter mill tooling?
    By gallegos in forum METALWORK GENERAL
    Last Post: 9th Sep 2013, 12:04 AM
  4. Starter band saw recommendation
    By skiffle in forum METALWORK GENERAL
    Last Post: 3rd Nov 2011, 06:59 PM
